.NET
dreamwtx
Message 1 of 7 (385 Views)
How to change the layer to be on or off using c#.net ?
385 Views, 6 Replies
03-08-2012 12:30 AM
I hope that i can implement the function not using dll file in autocad. just carry out it  in  out of autocad  .
Alfred.NESWADBA
Message 2 of 7 (364 Views)
Re: How to change the layer to be on or off using c#.net ?
03-08-2012 10:15 AM in reply to: dreamwtx
Not sure what you like to do now.
If you don't want to create a DLL but you want to develop in C# then you have to create an EXE and you have to use the COM-interface in such way:
ThisDrawing.Layers("myLayerName").LayerOn = false
Or you use VBA or LISP or SCRIPT or .... Or I'm fully wrong and didn't understand your question correctly, then sorry and please try to explain a little bit more detailed what you want to get.
- alfred -
Alfred NESWADBA
arcticad
Message 3 of 7 (361 Views)
03-08-2012 10:52 AM in reply to: Alfred.NESWADBA
I posted some code over here just a few minutes ago.
http://forums.autodesk.com/t5/NET/how-to-access-AutoCAD-2012-from-Vb-net-Standard-Exe/td-p/3363237
(defun botsbuildbots() (botsbuildbots))
dreamwtx
Message 4 of 7 (347 Views)
03-08-2012 05:32 PM in reply to: Alfred.NESWADBA
i  want to develop exe using c# which can call autocad and carry out change of  the property (such as layer on or off ,names of layers).  for example, i have a dwg than contains a few layers ,i wanna to close a layers then saveas a dwg.
  in fact,i am not sure that if the functions can be implemented  using c# and not using dll file. this  is just my idea. i also  don't know this way is wrong or right.  i just borrow ideas from secondary development  for solidworks
dreamwtx
Message 5 of 7 (343 Views)
03-08-2012 06:18 PM in reply to: Alfred.NESWADBA
could  you give me more codes like "ThisDrawing.Layers("myLayerName").LayerOn = false"?
- alfred -
Alfred.NESWADBA
Message 6 of 7 (332 Views)
03-09-2012 12:08 AM in reply to: dreamwtx
you got a link from articad for how to access AutoCAD (COM) from an exe.
Then take the document-object, within that you have a collection of Layers, search your layer (by key within the collection, I called it in the sample "myLayerName") and switch it off (property LayerOn)
There is not more code then the above line necessary to switch off a layer with a name you know.
- alfred -
Alfred NESWADBA
arcticad
Message 7 of 7 (322 Views)
03-09-2012 06:35 AM in reply to: Alfred.NESWADBA
http://www.developerfusion.com/tools/convert/vb-to-csharp/
