.NET
How to change scale using .NET or C#
7 REPLIES 7
Message 1 of 8
4804 Views, 7 Replies
Good evening all,
I want to change a scale of drawing (all entity) & save it
Help me I am using AutoCAD 2010
7 REPLIES 7
Message 2 of 8
Maybe the attached will help.
r,
dennis
Message 3 of 8
Hi djonio ,
Thanks a lot for reply it very useful
I am able to scale the view but I am facing problem to set origin
Please help
Message 4 of 8
Hi djonio
Thank's for reply.
how to change selected entity scale Only
Message 5 of 8
Hallex
Here is an quick xample how to do it
{code}
using System;
using System.Collections.Generic;
using System.Text;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.GraphicsInterface;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
// credits Tony Tanzillo
public static void Scale(ObjectId id, Point3d basept, double scale)
Matrix3d transform = Matrix3d.Scaling(scale,basept);
Database db = id.Database;
using (Transaction tr = db.TransactionManager.StartTransaction())
try
Entity ent = (Entity)tr.GetObject(id, OpenMode.ForWrite);
if (ent != null)
ent.TransformBy(transform);
tr.Commit();
catch (Autodesk.AutoCAD.Runtime.Exception ex)
AcadApp.ShowAlertDialog(ex.Message);
[CommandMethod("SCE")]
public static void ScaleSelected()
Document doc = AcadApp.DocumentManager.MdiActiveDocument;
Editor ed = doc.Editor;
PromptEntityOptions peo = new PromptEntityOptions("\nSelect an Entity: ");
PromptEntityResult res = ed.GetEntity(peo);
if (res.Status != PromptStatus.OK)
return;
PromptPointOptions ppo = new PromptPointOptions("\nPick Base Point: ");
PromptPointResult pres = ed.GetPoint(ppo);
if (pres.Status != PromptStatus.OK)
return;
PromptDoubleOptions pdo = new PromptDoubleOptions("\nSpecify Scale Factor: ");
PromptDoubleResult dres = ed.GetDouble(pdo);
if (dres.Status != PromptStatus.OK)
return;
ObjectId id = res.ObjectId;
Point3d basept =pres.Value;
double scale = dres.Value;
Scale(id, basept, scale);
{code}
~'J'~
Message 6 of 8
Hi hallex ,
Thanks again
Thank you so muchhhhhhhhh for the reply.
Have a nice Day
Message 7 of 8
Hallex
Glad if that worked
Have a nice day
~'J'~
Message 8 of 8
in reply to: Hallex
Does anyone know how to let the user scale the objects?  I need users to be able to see exactly how their scale is going to turn out.
”Boost
