.NET
.NET
1 Kudo
Post 1 of 2
How to change plot device but leave default paper size (media name)?
521 Views, 1 Replies
04-03-2012 02:06 PM
Now I'm going to write a code that will change current plot device of the drawing and there isn't a problem here:
acPlSetVdr.SetPlotConfigurationName(acPlSet, newPrinter, "A4");
But how can I leave default paper size not "A4"? For example if there is "A3" it should stay "A3". Because if I go through each drawing I don't know what is the current paper size I just need to change the plot device becuse default has been crashed for example. But if I write "A4" each drawing will have "A4".
Hope I explain everything clearly. Thanx for suggestions.
44 Kudos
Post 2 of 2
Re: How to change plot device but leave default paper size (media name)?
04-04-2012 11:54 PM in reply to: Dasharnb777
The way to do this might depend on printer type etc.
1: If possible create two PC3 for one printer, one configured for A4 and one for A3.
2. you might change youre local printer calling printui.dll like this
    using System.Management;
    using System.Printing;
    ProcessStartInfo startInfo = new ProcessStartInfo();
        startInfo.FileName = "rundll32.EXE";
        startInfo.Arguments = "Printui.dll,PrintUIEntry /ia /K /q /m "SHARP MX-5500N PS" /h "Windows NT x86" /v 3 /f sn0hwenu.inf";
        Process.Start(startInfo);
        //.WshShell shell = new IWshRuntimeLibrary.WshShell();
        //string command = "RUNDLL32 PRINTUI.DLL,PrintUIEntry /k /n \"" + printerInfo.PrinterName + "\"";
        //object windowStyle = null;
        //object waitOnReturn = null;
        //shell.Run(command, ref windowStyle, ref waitOnReturn);
3. configure youre default printer with the required papersize, then export these settings
     rundll32 printui.dll,PrintUIEntry /Ss /n "ThePrinter" /a "C:\temp\ThePrinter_A4.dat" 9
    and import these settings with
     rundll32 printui.dll,PrintUIEntry /Sr /n "ThePrinter" /a "C:\temp\ThePrinter_A4.dat" 9
Set default printer: rundll32 printui.dll,PrintUIEntry /y /n "ThePrinter"
4. change registry,  see
     HKEY_CURRENT_USER\Printers\DevModePerUser\ThePrinter
     and HKEY_CURRENT_USER\Printers\DevModes2\
    settings might be exported and imported using DOS cmd
     C:\WINNT\system32\reg.exe import c:\temp\ThePrinter_A4.reg
These articles may give you some background.
    changing printing preferences
    http://www.lessanvaezi.com/changing-printer-settings-using-the-windows-api/
    Save/restore Devmode
    http://nicholas.piasecki.name/blog/2008/11/programmatically-selecting-complex-printer-options-in-c-s...
    Set+Get Default printer via registry
    http://www.xtremedotnettalk.com/showthread.php?t=83348
