.NET
how to change GetVariable("tdcreate") to date format
5 REPLIES 5
1463 Views, 5 Replies
hi
i am useing vb.net 2010
        Dim AcadApp As Autodesk.AutoCAD.Interop.AcadApplication
        Dim acaddoc As Autodesk.AutoCAD.Interop.AcadDocument
        AcadApp = GetObject(, "Autocad.Application")
        acaddoc = AcadApp.ActiveDocument
        Dim DD As Double
        DD = acaddoc.GetVariable("tdcreate")
how to convert DD value to date and time format
any suggestion will be great.
Thanks in advance.
5 REPLIES 5
kdub_nz
http://lmgtfy.com/?q=julian+date+converter+C%23+VB.net
// Called Kerry in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>;      another  Swamper
Keith.Brown
in reply to: kdub_nz
Nice link Kerry.  Is amazing to me what type of websites people think up.
kdub_nz
Something to play with :
http://www.theswamp.org/index.php?topic=41190.msg463478#msg463478
yes. this is it.
thanks
Thanks for awesome code.
Could you help me how to get time upto milliseconds.
In your example 03/12/2012 16:25:07:046.
How can I get milliseconds?
Thanks in advance,
thenndral
”Boost
