.NET
How to change all the DOCUMENTS of the TileMode to 0.
5 REPLIES 5
classof
990 Views, 5 Replies
Hello
I would like to change all the DOCUMENTS of the TileMode to 0.
But, the following code the ActiveDocument changes only.
How can I modify the code?
Dim acdc As DocumentCollection = Application.DocumentManager
        Dim acdoc As Document = acdc.MdiActiveDocument
        Dim acTile As Integer = Application.GetSystemVariable("TileMode")
        For Each acdoc In acdc
            If acTile = 1 Then
                Application.SetSystemVariable("TILEMODE", 0)
        Next
    End Sub
5 REPLIES 5
Hallex
in reply to: classof
Take a look at the article
        'See article here:
        'http://adndevblog.typepad.com/autocad/2012/05/when-to-lock-the-document.html?cid=6a0167607c2431970b0...
        <CommandMethod("stile")> _
        Public Sub switchTileMode()
            Try
                For Each doc As Document In Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
                    If doc <> Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument Then
                        ' switch the active document
                        Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument = doc
                        ' If you do not lock the document
                        ' then the below code just simply has no effect
                        ' whereas "doc.Database.TileMode =
                        ' !doc.Database.TileMode;"
                        ' would even crash AutoCAD
                        ' If you lock the document then both should  work fine
                        Using doc.LockDocument()
                            Dim tm As Short = CShort(Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("TILEMODE"))
                            Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("TILEMODE", (tm + 1) Mod 2)
                        End Using
                        Exit For
                Next
            Catch ex As Autodesk.AutoCAD.Runtime.Exception
                Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(("Exception: " + ex.Message))
            Finally
                ' Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.CloseAll() 'to your needs
            End Try
        End Sub
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
classof
in reply to: Hallex
Hallex
Thank you for your reply.
So, I made the following code.. but, Tilemod of all document does not change the value to 0.
Please help me..
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.ApplicationServices
Public Class fsfaf
    <CommandMethod("ss")> _
    Public Sub ypf()
        For Each acdoc As Document In acdc
            If acdoc <> acdc.MdiActiveDocument Then
                acdc.MdiActiveDocument = acdoc
            Using acdoc.LockDocument()
                Dim acTile As Short = Application.GetSystemVariable("TileMode")
                If acTile = 1 Then
            End Using
        Next
    End Sub
End Class
BlackBox_
in reply to: Hallex
        'See article here:
            '' <snip>
        End Sub
Hallex,
Doesn't the article say that CommandFlags.Session is needed?
Example code snippet from the article you linked above:
// <snip>
[CommandMethod("MyTest", CommandFlags.Session)] public void MyTestNet() { // <snip> }
Cheers
"How we think determines what we do, and what we do determines what we get."
classof
I have solved this problem. Smiley Happy
I have added the CommandFlags.Session.
thank you~
BlackBox_
thank you~
If only someone had suggested that before... Regardless, glad you got it sorted.
Cheers
”Boost
