.NET
.NET
0 Kudos
Post 1 of 6
How to change all the DOCUMENTS of the TileMode to 0.
418 Views, 5 Replies
05-16-2013 08:35 PM
Hello
I would like to change all the DOCUMENTS of the TileMode to 0.
But, the following code the ActiveDocument changes only.
How can I modify the code?
Dim acdc As DocumentCollection = Application.DocumentManager
        Dim acdoc As Document = acdc.MdiActiveDocument
        Dim acTile As Integer = Application.GetSystemVariable("TileMode")
        For Each acdoc In acdc
            If acTile = 1 Then
                Application.SetSystemVariable("TILEMODE", 0)
            End If
        Next
    End Sub
Take a look at the article
 'See article here:
'http://adndevblog.typepad.com/autocad/2012/05/when-to-lock-the-document.html?cid=6a0167607c2431970b0177443a993b970d
<CommandMethod("stile")> _
Public Sub switchTileMode()
Try
For Each doc As Document In Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
If doc <> Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument Then
' switch the active document
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument = doc
' If you do not lock the document
' then the below code just simply has no effect
' whereas "doc.Database.TileMode =
' !doc.Database.TileMode;"
' would even crash AutoCAD
' If you lock the document then both should work fine
Using doc.LockDocument()
Dim tm As Short = CShort(Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("TILEMODE"))
Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("TILEMODE", (tm + 1) Mod 2)
End Using
Exit For
End If
Next
Catch ex As Autodesk.AutoCAD.Runtime.Exception
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(("Exception: " + ex.Message))
Finally
' Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.CloseAll() 'to your needs
End Try
End Sub
171 Kudos
Post 2 of 6
Re: How to change all the DOCUMENTS of the TileMode to 0.
05-18-2013 04:39 AM in reply to: classof
        'See article here:
        'http://adndevblog.typepad.com/autocad/2012/05/when-to-lock-the-document.html?cid=6a0167607c2431970b0...
            Try
                        End Using
                        Exit For
                    End If
                Next
            Finally
            End Try
        End Sub
0 Kudos
Post 3 of 6
06-05-2013 04:11 AM in reply to: Hallex
Hallex
Thank you for your reply.
So, I made the following code.. but, Tilemod of all document does not change the value to 0.
Please help me..
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.ApplicationServices
Public Class fsfaf
    <CommandMethod("ss")> _
    Public Sub ypf()
        For Each acdoc As Document In acdc
            If acdoc <> acdc.MdiActiveDocument Then
                acdc.MdiActiveDocument = acdoc
            End If
            Using acdoc.LockDocument()
                Dim acTile As Short = Application.GetSystemVariable("TileMode")
                If acTile = 1 Then
                End If
            End Using
        Next
    End Sub
End Class
Distinguished Mentor
80 Kudos
Post 4 of 6
06-05-2013 07:25 AM in reply to: Hallex
        'See article here:
            '' <snip>
        End Sub
Hallex,
Doesn't the article say that CommandFlags.Session is needed?
Example code snippet from the article you linked above:
// <snip>
[CommandMethod("MyTest", CommandFlags.Session)] public void MyTestNet() { // <snip> }
Cheers
"Potential has a shelf life." - Margaret Atwood
Autodesk Exchange Apps ~ Autoloader ~ AutoCAD Security
AutoCAD® 2014, and Civil 3D® 2014 Certified Professional ~ Autodesk® Authorized Developer
0 Kudos
Post 5 of 6
06-05-2013 06:42 PM in reply to: classof
I have solved this problem. :smileyhappy:
I have added the CommandFlags.Session.
thank you~
80 Kudos
Post 6 of 6
06-05-2013 09:37 PM in reply to: classof
thank you~
If only someone had suggested that before... Regardless, glad you got it sorted.
Cheers
