.NET
.NET
Valued Contributor
1 Kudo
Post 1 of 3
How to change a polyline shape if it intersect with another
199 Views, 2 Replies
06-21-2012 08:45 AM
Hi Guys,
I have 2 polyline. First I need to know whether those 2 polyline intersect with each other or not. If they are I need to change one of the polyline shape deduct the intersection area.
How can I do that?
Thanks very much
Distinguished Contributor
4 Kudos
Post 2 of 3
Re: How to change a polyline shape if it intersect with another
06-21-2012 09:39 AM in reply to: yaqiz
Here's a start.
171 Kudos
Post 3 of 3
06-21-2012 01:22 PM in reply to: yaqiz
Here is a start too
        <CommandMethod("Remarea")> _
        Public Shared Sub DeductPolyline()
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim ed As Editor = doc.Editor
            Dim db As Database = doc.Database
            'start a transaction
            Using tr As Transaction = db.TransactionManager.StartTransaction()
                Dim tvs As TypedValue() = New TypedValue() {New TypedValue(0, "lwpolyline"), New TypedValue(70, 1)}
                Dim filter As New SelectionFilter(tvs)
                Dim pso As New PromptSelectionOptions()
                pso.MessageForRemoval = vbLf & "Select 2 closed polylines only: "
                pso.MessageForAdding = vbLf & "Select 2 closed polylines: "
                Dim result As PromptSelectionResult = ed.GetSelection(filter)
                If result.Status <> PromptStatus.OK Then
                    Return
                End If
                If result.Value.Count <> 2 Then
                    Return
                End If
                Dim sset As SelectionSet = result.Value
                Dim ids As ObjectId() = sset.GetObjectIds()
                Dim obj As DBObject = TryCast(tr.GetObject(ids(0), OpenMode.ForRead), DBObject)
                Dim pline1 As Polyline = TryCast(obj, Polyline)
                If pline1 Is Nothing Then
                    Return
                End If
                obj = TryCast(tr.GetObject(ids(1), OpenMode.ForRead), DBObject)
                Dim pline2 As Polyline = TryCast(obj, Polyline)
                If pline2 Is Nothing Then
                    Return
                End If
                Dim pts As New Point3dCollection()
                pline1.IntersectWith(pline2, Intersect.OnBothOperands, pts, CInt(IntPtr.Zero), CInt(IntPtr.Zero))
                If pts.Count = 0 Then
                    Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("Polylines doesn't intersects each other, Exit")
                    Return
                End If
                ' add the polylines to the array
                Dim objArray1 As New DBObjectCollection()
                objArray1.Add(pline1)
                ' create the 1 st region
                Dim objreg1 As New Region()
                Dim objRegions1 As New DBObjectCollection()
                objRegions1 = Region.CreateFromCurves(objArray1)
                objreg1 = TryCast(objRegions1(0), Region)
                Dim objArray2 As New DBObjectCollection()
                objArray2.Add(pline2)
                ' create the 2nd region
                Dim objreg2 As New Region()
                Dim objRegions2 As New DBObjectCollection()
                objRegions2 = Region.CreateFromCurves(objArray2)
                objreg2 = TryCast(objRegions2(0), Region)
                Dim btr As BlockTableRecord = DirectCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite, False), BlockTableRecord)
                ' Subtract region 1 from region 2
                If objreg1.Area > objreg2.Area Then
                    ' Subtract the smaller region from the larger one
                    objreg1.BooleanOperation(BooleanOperationType.BoolSubtract, objreg2)
                    objreg2.Dispose()
                    ' Add the final region to the database
                    btr.AppendEntity(objreg1)
                    tr.AddNewlyCreatedDBObject(objreg1, True)
                    objreg1.ColorIndex = 1
                Else
                    objreg2.BooleanOperation(BooleanOperationType.BoolSubtract, objreg1)
                    objreg1.Dispose()
                    btr.AppendEntity(objreg2)
                    tr.AddNewlyCreatedDBObject(objreg2, True)
                    objreg2.ColorIndex = 1
                End If
                tr.Commit()
            End Using
        End Sub
~'J'~
