.NET
How to change a dimensional constraint from annotational to dynamic?
1 REPLY 1
396 Views, 1 Reply
public class DimConstraints
    [CommandMethod("Test")]
    public void Test()
        Database db = HostApplicationServices.WorkingDatabase;
        using (Transaction trans = db.TransactionManager.StartTransaction())
            Circle circle = new Circle { Center = Point3d.Origin, Radius = 10 };
            ObjectId modelId = SymbolUtilityServices.GetBlockModelSpaceId(db);
            BlockTableRecord model = (BlockTableRecord)modelId.GetObject(OpenMode.ForWrite);
            model.AppendEntity(circle);
            trans.AddNewlyCreatedDBObject(circle, true);
            AssocUtil.CreateRadialDimConstraint(circle.ObjectId, circle.StartPoint, circle.StartPoint);
            trans.Commit();
The above codes use the simplified .NET API for accessing AutoCAD parameters and constraints from:
http://through-the-interface.typepad.com/files/AdnAssocConstraintAPI.zip
The above codes can create a radial dimensional constraint.
But the type of the dimensional constraint is annotational.
How to change it to a dynamic constraint?
1 REPLY 1
philippe.leefsma
Hi
This setting is not exposed through this high level constraint API.
In order to set a constraint dynamic, you need to use the "AcDbDimension::setConstraintDynamic(true)" on the dimension on which you apply the constraint. You will need to modify the source code of the C++ API in order to achieve that.
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
”Boost
