.NET
How to change 2. poly's coordinate in poly series
2 REPLIES 2
awdas
347 Views, 2 Replies
I can draw poly by c# code but how to convert UCS 2. poly
I want to do as follows
2 REPLIES 2
awdas
in reply to: awdas
I have 2 polyline, draw first polyline and extrude region along this polyline after this process second polyline start correctly position (move 2. polyline start point to 1. polyline end point) but I can't transform second polyline to correct direction.
Balaji_Ram
in reply to: awdas
Can you please share a simple buildable project to demonstrate the issue ?
It will be a lot easier to debug and spot the error.
Balaji
Developer Technical Services
Autodesk Developer Network
”Boost
