.NET
.NET
Valued Mentor
53 Kudos
Post 21 of 29
Re: How to capture double click event in AutoCAD using VB.NET
12-06-2012 11:10 PM in reply to: Balaji_Ram
I was wondering about that and have not had time to test but setting it pick first selection then sending the command will work.
I was unsure about the 3 clicks but just guessing was sending the command without a active pickset and was getting a prompt to select an entity.
You can also find your answers @ TheSwamp
Valued Contributor
1 Kudo
Post 22 of 29
12-07-2012 09:40 AM in reply to: jeff
You are so right! The 3 clicks are as a result of sending the command without a active pickset and thereby getting a prompt to select an entity. I tried using the 'L' for last pickset in the eattedit command, but I didn't like what it was doing, it seemed to be malfunctioning in the context it was being used, always retaining the id of last picked object no matter what.
I strive for perfection, so ideally, I really don't want those 3 clicks, as I am sure it would eventually become a nuisance for the end user...
Valued Contributor
1 Kudo
Post 23 of 29
12-07-2012 10:36 AM in reply to: Balaji_Ram
Balaji,
I just implemented your solution, and it worked! I am truly grateful for the help. I do have a question though: the macro command
"$M=$(if,$(and,$(>,$(getvar,blockeditlock),0)),^C^C_properties,^C^C_mybedit)";
seems to be configured fro blocks; how do I configure it for attribute blocks? I already tried doing this:
"$M=$(if,$(and,$(>,$(getvar,blockeditlock),0)),^C^C_eattedit,^C^C_mybedit)";
but when I test the double click on an attribute block (not one that show show my form), the block properties editor pops up instead of the attributes editor.
Any ideas?
ADN Support Specialist
100 Kudos
Post 24 of 29
12-10-2012 06:32 AM in reply to: mindofcat
The double click action for an attribute block is different from the double click action for a block.
You can see these two actions using the CUI dialog as seen in the attachment.
To customize the double click for an attribute block, here are some changes to the code snippet that I posted earlier
1) Check for "dca.Name.Equals("Attribute Block"))" instead of "dca.Name.Equals("Block"))"
2) Change the double click macro to "^C^C_mybedit" instead of "$M=$(if,$(and,$(>,$(getvar,blockeditlock),0)),^C^C_properties,^C^C_mybedit)";"
3) Change the "SendStringToExecute" inside the "MyBedit" command to send the "eattedit" command if it not a block reference that you are interested in.
Please let me know if you have any issues in getting this to work.
Balaji
Developer Technical Services
Autodesk Developer Network
Valued Contributor
1 Kudo
Post 25 of 29
12-10-2012 11:03 AM in reply to: Balaji_Ram
Wow! That worked wonders! Thanks a million!
However, even after implementation, I'm still having 3 clicks for attribute blocks other than those being edited by my form. So I'm guessing the ed.SetImpliedSelection(ids) called before sendStringToExecute still is empty; if I double click on an attribute block not being edited by my form, the AutoCAD prompt says "select a block: " and then I have to click on the block once more in order for the eattedit editor to be displayed.
Any ideas on how to get that implied selection set to work so I don't have to click three times?
Thanks again for all the help.
Cat
100 Kudos
Post 26 of 29
12-11-2012 01:11 AM in reply to: mindofcat
I could reproduce the same behavior. It seems that AutoCAD was clearing the pickfirst selection before the eattedit command was executed.
Using "CommandFlags.UsePickSet | CommandFlags.Redraw" for the "mybedit" command resolves the issue.
Thanks to my colleague, Viru for suggesting this fix.
Balaji
Valued Contributor
1 Kudo
Post 27 of 29
12-11-2012 11:12 AM in reply to: Balaji_Ram
Worked like a charm! Now I can successfully double-click on an attribute block, and either display my form, or go straight to AutoCAD's eattedit command. The combined command flags successfully resolved the triple clicks issue as well. I am truly grateful for all the help accorded me in the successful resolution of this problem.
Thanks Balaji, thanks Jeff, thanks Viru, thanks Autodesk NET forum!
100 Kudos
Post 28 of 29
12-12-2012 04:28 AM in reply to: mindofcat
I am glad you have resolved the issue.
Good luck.
Balaji
Active Contributor
1 Kudo
Post 29 of 29
12-12-2012 05:10 AM in reply to: jeff
Hello mindofcat
Would you ask me about the program disposal.
Thank you
Hallo mindofcat
Würden Sie das Programm mir zu verfügung stellen.
Danke
DH
