.NET
.NET
Valued Contributor
1 Kudo
Post 1 of 29
How to capture double click event in AutoCAD using VB.NET
1674 Views, 28 Replies
11-26-2012 06:16 PM
Hi all,
I`m still trying to find a solution to my previous post, displaying a vb.net form when an autocad block reference is double-clicked. Unfortunately, I still don`t know how to capture the double-click event for a block reference from code. I have gone down the IMessageFilter path, still no success.
I have tried the addHandler for application using code supplied to me in my previous post, still no luck. I really need to be able to capture the doubleclick event for a block reference in autocad, without overwriting the default autocad double-click behavior.
I wish to be able to double-click a block reference, capture its name, and, if the name is same as blocks created by my form, then I`d simply have my dot net form pop up, displaying a few of the block`s properties.
Does anyone have any ideas on how this might be accomplishedÉ
Below is the code module I am using, which isn`t working ofr me:
' System
Imports Microsoft.Win32
Imports System.Reflection
' AutoCAD
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Runtime
Imports acApp = Autodesk.AutoCAD.ApplicationServices.Application
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
' AutoCAD Interop
Imports acOp = Autodesk.AutoCAD.Interop
Imports acOpCom = Autodesk.AutoCAD.Interop.Common
Module ModDoubleClick
Private acDoc As acOp.AcadDocument
Private handlerAdded As Boolean = False
Public Sub eventDoubleClick()
    Try
        If handlerAdded = False Then
            acApp.SetSystemVariable("DBLCLKEDIT", 0)
            If acDoc Is Nothing Then
                acDoc = CType(acApp.DocumentManager.MdiActiveDocument.AcadDocument, _
                Autodesk.AutoCAD.Interop.AcadDocument)
                AddHandler acDoc.BeginDoubleClick, AddressOf callback_DoubleClick
            End If
            handlerAdded = True
        End If
    Catch ex As Autodesk.AutoCAD.Runtime.Exception
        MsgBox(ex.Message, MsgBoxStyle.Critical)
    Finally
        acApp.SetSystemVariable("DBLCLKEDIT", 1)
    End Try
End Sub
Private Sub callback_DoubleClick(ByVal PickPoint As Object)
    Dim activeDoc As Document = acApp.DocumentManager.MdiActiveDocument
    Dim prmtSel As PromptSelectionResult = activeDoc.Editor.GetSelection()
    Using docLock As DocumentLock = activeDoc.LockDocument()
        If prmtSel.Status <> PromptStatus.OK Then Return
        If prmtSel.Value.Count <> 1 Then Return
        Dim id As Autodesk.AutoCAD.DatabaseServices.ObjectId = _
        prmtSel.Value(0).ObjectId
        Using acTrans As Autodesk.AutoCAD.DatabaseServices.Transaction = _
        activeDoc.TransactionManager.StartTransaction()
            Dim dbObj As Autodesk.AutoCAD.DatabaseServices.DBObject = _
            acTrans.GetObject(id, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite)
            Dim ent As Autodesk.AutoCAD.DatabaseServices.Entity = _
            TryCast(dbObj, Autodesk.AutoCAD.DatabaseServices.Entity)
            If ent Is Nothing Then
                Return
            Else
                Dim blockRef As Autodesk.AutoCAD.DatabaseServices.BlockReference = _
                TryCast(ent, Autodesk.AutoCAD.DatabaseServices.BlockReference)
                If blockRef Is Nothing Then
                    Return
                Else
                    activeDoc.Editor.WriteMessage(blockRef.Name)
                End If
            End If
            acTrans.Commit()
        End Using
    End Using
End Sub
End Module
And the Commands class, from which my vb.net form is generated, as well as where the ModDoubleClick.eventDoubleClick() method is called:
Public Class Commands
    ' Component for displaying the Mass Straight Conveyor form
    <CommandMethod("mst")> _
    Public Shared Sub massStraight()
        Try
            ' Call this to override default block dblclk event handler
            ' Display the mass straight form
            Dim cForm As New frmMassStraight
            acApp.ShowModalDialog(cForm)
        End Try
    End Sub
End Class
Any help is greatly appreciated!
Many thanks...
Cat
Thanks very much, this helped immensely. Truly grateful for the help.
Worked like a charm! Now I can successfully double-click on an attribute block, and either display my form, or go straight to AutoCAD's eattedit command. The combined command flags successfully resolved the triple clicks issue as well. I am truly grateful for all the help accorded me in the successful resolution of this problem.
Thanks Balaji, thanks Jeff, thanks Viru, thanks Autodesk NET forum!
Distinguished Contributor
2 Kudos
Post 2 of 29
Re: How to capture double click event in AutoCAD using VB.NET
11-27-2012 06:58 AM in reply to: mindofcat
See if this might help;
http://www.theswamp.org/index.php?topic=40021.0
ACADuser
Civil 3D 2015, Raster Design 2015
Windows 7 Enterprise
Dell Precision T5500 Workstation
Dual Quad Core Intel Xeon 2.53GHz Processors
24GB RAM, NVIDIA Quadro FX 4800 1.5GB
DUAL 27" Dell UltraSharp U2713HM
Valued Contributor
11 Kudos
Post 3 of 29
11-27-2012 07:30 AM in reply to: mindofcat
This code seems to be working OK for me as far as capturing the event.  You are creating and displaying the form at the wrong place however.  I think these 2 lines of code shouldn't be part of your command that's setting up the handler:
but instead have to be called before your callback returns.  If you try to run this but you double click on something other than a block reference you might Return prematurely.  I would suggest you print out the Type of your entity just to be sure you are double clicking on the right entity before you return:
ed.WriteMessage(vbLf & "Type:        " + ent.GetType().ToString())
You should see:
Type:        Autodesk.AutoCAD.DatabaseServices.BlockReference
as opposed to something like this:
Type:        Autodesk.AutoCAD.DatabaseServices.Solid3d
or something else.  Hope this helps
Valued Mentor
53 Kudos
Post 4 of 29
11-27-2012 08:31 AM in reply to: sszabo
Valued Contributor
1 Kudo
Post 5 of 29
11-27-2012 12:14 PM in reply to: ACADuser
Thanks... the article shows me a code structure that is quite similar to the one I already have. My code should work, but it isn't, I am not seeing the desired result, and I'm guessing this is probably as a result of HOW I'm calling its command.
This whole thing is so confusing. I even seperated the doubleclick module into its own calling command (complete with usepickset), so that I could draw a block, then execute the doubleclick command, and then double-click on the block to see if anything happens... nothing. Just the same ol' AutoCAD attributes editor.
Really frustrating!
Valued Contributor
1 Kudo
Post 6 of 29
11-27-2012 12:20 PM in reply to: jeff
And as well, I have also been to http://adndevblog.typepad.com/autocad/2012/09/displaying-entity-details-on-double-click.html many days ago; I translated the code to dot net, and executed it. When I go to AutoCAD and type cui in the command to pull up the cui editor, I see that my new double click action has been created alright, but I still don't know how to attach it to block references, or how to modify the macro string to open my vb.net form.
The macro string in the article runs thus:
C^C^myForm
How does this get modified to pop up a vb.net form named frmMassStraight which I would normally open using application.showModalDialog(formInstance)
Thanks all, for your help, but I'm still floundering in the dark, trying so hard to see the light which I know exists at the end of this dark tunnel...
Valued Contributor
1 Kudo
Post 7 of 29
11-27-2012 12:27 PM in reply to: mindofcat
Does anyone know of any professional AutoCAD VB.NET Customization Consultants whom I can pay for their time in order to discuss this doubleclick action problem on the phone or via email, in the hope of finding a feasible solution?
Many thanks in advance...
Cat
Valued Contributor
11 Kudos
Post 8 of 29
11-27-2012 12:35 PM in reply to: mindofcat
I am not sure I understand what is the problem.. Your code works perfectly with minor changes.
I replaced your cForm with one that has a textbox1 that displays all the properties of the objects you double click.  It should help you identify/discover any issues.  Alll you should have to do is add a winform to your project and drag a textbox1 on it:
 Keep me posted where is your code failing exactly, because this works for me.  Also, I am using AutoCAD 2013, it should be easy to replace document code relevant to 2012 or earlier.
        Public db As Database = HostApplicationServices.WorkingDatabase
        Public ed As Editor = activeDoc.Editor
        Public ReadOnly Property ThisDrawing() As AcadDocument
            Get
                Return DocumentExtension.GetAcadDocument(Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument)
            End Get
        End Property
        Private cForm As New frmMassStraight
            Try
                    MgdAcApplication.SetSystemVariable("DBLCLKEDIT", 0)
                        acDoc = CType(ThisDrawing, Autodesk.AutoCAD.Interop.AcadDocument)
                    End If
                    handlerAdded = True
                End If
            Finally
                MgdAcApplication.SetSystemVariable("DBLCLKEDIT", 1)
            End Try
        End Sub
        Private Sub DisplayError(ByVal msg As String)
            ed.WriteMessage(vbLf + msg)
            cForm.TextBox1.Text += msg + vbCrLf
            MgdAcApplication.ShowModalDialog(cForm)
        End Sub
            Dim msg As String = ""
                    DisplayError(String.Format("ERROR: prmtSel.Status= {0}", prmtSel.Status))
                    Return
                End If
                    DisplayError(String.Format("ERROR: prmtSel.Value.Count={0}", prmtSel.Value.Count))
                    Return
                End If
                Dim id As Autodesk.AutoCAD.DatabaseServices.ObjectId = prmtSel.Value(0).ObjectId
                Try
                        cForm.Text = ent.GetType().ToString()
                        For Each p As System.Reflection.PropertyInfo In ent.GetType().GetProperties()
                            Try
                                Dim displStr As String = String.Format("  {0}:     '{1}'", p.Name, p.GetValue(ent, Nothing))
                                cForm.TextBox1.Text += displStr + vbCrLf
                            Catch
                                Dim msgStr As String = String.Format("ERR: '{0}' p='{1}'", Err.Description, p.ToString)
                                ed.WriteMessage(vbLf + msgStr)
                                cForm.TextBox1.Text += msgStr + vbCrLf
                            End Try
                        Next
                            DisplayError(String.Format("ERROR: ent={0}", ent))
                            Return
                        Else
                                DisplayError(String.Format("ERROR: blockRef={0}", blockRef))
                                Return
                            Else
                                activeDoc.Editor.WriteMessage(blockRef.BlockName)
                            End If
                        End If
                        acTrans.Commit()
                    End Using
                    Dim msgStr As String = String.Format("EX: '{0}'", ex.ToString)
                Catch
                    Dim msgStr As String = String.Format("ERR: '{0}'", Err.Description)
                End Try
            End Using
        End Sub
        Public Sub massStraight()
            Try
                eventDoubleClick()
            End Try
        End Sub
Valued Contributor
1 Kudo
Post 9 of 29
11-27-2012 01:41 PM in reply to: sszabo
Thanks a bunch. Let me try out your suggestion, and see if I can pinpoint where I am making my mistake.
I shall keep you posted on the development.
Many thanks...
Valued Contributor
1 Kudo
Post 10 of 29
11-27-2012 07:21 PM in reply to: sszabo
Hi sszabo,
I`ve implemented the code revision you so kindly provided. However, when I run the `mst` command, nothing happens. I doubleclick on a block after running the command, and the attributes editor is what I see still.
Here is the code I have:
' System
Imports System
Imports System.Collections.Generic
Imports System.Linq
Imports System.Text
Imports System.Linq.Expressions
' AutoCAD
' AutoCAD Interop
<Assembly: CommandClass(GetType(Test.Commands))>
Namespace Test
        Public activeDoc As Document = acApp.DocumentManager.MdiActiveDocument
        Private cForm As New frmMassStraight ' I already have a form called frmMassStraight, so I simply added a Textbox1 to it
        ' I tried using the property call, but was getting an error on type mismatch from document to acadDocument
        Public Function ThisDrawing()
            Return acApp.DocumentManager.MdiActiveDocument.AcadDocument
        End Function
            Try
                    End If
                    handlerAdded = True
                End If
            Finally
            End Try
        End Sub
        Private Sub displayError(ByVal msg As String)
        End Sub
        Private Sub callback_DoubleClick(ByVal pickPoint As Object)
                    displayError(String.Format("Error: prmtSel.Status= {0}", prmtSel.Status))
                    Return
                End If
                    displayError(String.Format("Error: prmtSel.Value.Count={0}", _
                End If
                Try
                        For Each p As System.Reflection.PropertyInfo In _
                            Try
                                Dim displStr As String = String.Format(" {0}:      '{1}'", _
                            Catch
                                Dim msgStr As String = String.Format("Error: '{0}' p='{1}'", _
                            End Try
                        Next
                            displayError(String.Format("Error: ent={0}", ent))
                            Return
                        Else
                                displayError(String.Format("Error: blockRef={0}", blockRef))
                                Return
                            Else
                            End If
                        End If
                        acTrans.Commit()
                    End Using
                Catch
                    Dim msgStr As String = String.Format("ERR: '{0}", Err.Description)
                End Try
            End Using
        End Sub
            Try
                ' Call this to override the default block dblclk event handler
                eventDoubleClick()
            End Try
        End Sub
    End Class
End Namespace
I wonder if the problem is because I used the wrong document translations here. I am developing in an AutoCAD 2010 environment, and probably used the wrong instances for your equivalent of DocumentExtension.GetAcadDocument() as well as MgdAcApplication.
As it is, this code should work, but I am not seeing the desired effect. The form doesn`t pop up at all, so I can`t even tell what`s wrong. However, in an attempt to debug, I am guessing that the showModalDialog code at the end of the doubleclick callback probably isn`t being reached at all, which is why the form does not pop up at all to show me anything.
Not even the commandline shows me any of the messages I am supposed to see in the event of an error, or successful call.
Any ideas,
Thanks in advance...
