.NET
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
How to cancel a order before use .net API?
1 REPLY 1
348 Views, 1 Reply
I know the way to sendCommand to AutoCAD will cancel one order . I mean is there any other way to use .net API to cancel  one order but not using 'SendCommand'
1 REPLY 1
DiningPhilosopher
It depends on what you mean by 'order'.  If it is a command, you can veto the command from a handler of the DocumentLockModeWillChange event of the DocumentCollection.
ā€Boost
