.NET
.NET
1 Kudo
Post 1 of 10
How to call AutoCAD Command with .net C# on runtime?
2535 Views, 9 Replies
09-03-2012 12:20 AM
Dear All,
Season Greetings,
Needed experts help,
For Example,
After opening my Drawing File thro. .net C#,
                acApp.ActiveDocument.Application.ZoomExtents();
I need to use the AutoCAD command Oleopen
                acApp.ActiveDocument.BeginCommand.oleopen();
Here is some error.
Normally how to use the AutoCAD commands with .net C# programming.
Could you pleae help me?
regards,
Micky.
171 Kudos
Post 2 of 10
Re: How to call AutoCAD Command with .net C# on runtime?
09-03-2012 01:01 PM in reply to: Micky_1
I think you can use SendCommand,
See this thread:
http://forum.dwg.ru/showthread.php?t=84180
~'J'~
1 Kudo
Post 3 of 10
09-04-2012 02:52 AM in reply to: Hallex
Dear Mr. Hallex,
Thanks for your quick response,
In my coding,
<quote>
conststring progID = "AutoCAD.Application.18";
AcadApplication acApp = null;
try
acApp = (AcadApplication)Marshal.GetActiveObject(progID);
catch
try
Type acType = Type.GetTypeFromProgID(progID);
                    acApp = (AcadApplication)Activator.CreateInstance(acType,true);
catch
MessageBox.Show("Cannot create object of type \"" + progID + "\"");
if (acApp != null)
                acApp.Visible =true;
                acApp.ZoomExtents();
                acApp.ActiveDocument.SendCommand("oleopen\r");
<unquote>
the error which i am getting is
<quote>
Command: oleopen
Unable to find OLE object.  Object must be selected before entering the
OLESCALE command.
<unquote>
I have tried with the reference link sent by you,
Similarly I have tried to select the Ole Object and then to SendCommand "Oleopen", But I am getting some errors.
<quote>
 using (Transaction t = db.TransactionManager.StartTransaction()) {
BlockTableRecord bt = t.GetObject(db.CurrentSpaceId, OpenMode.ForRead) as BlockTableRecord;
foreach (ObjectId id in bt) {
if (id.ObjectClass.Name != "AcDbOle2Frame")
continue;
Ole2Frame oleFrame = t.GetObject(id, OpenMode.ForRead) as Ole2Frame;
IntPtr ptrClientItem = AcDbOle2Frame_getOleClientItem(oleFrame.UnmanagedObject);
COleClientItem_CopyToClipboard(ptrClientItem, 0);
t.Commit();
<unquote>
Could you please help me?
regards,
Micky.
171 Kudos
Post 4 of 10
09-04-2012 03:41 AM in reply to: Micky_1
If this ole object was inserted to model spce
try this code, tested on my A2010
Don't forget to release AcadApplication at the end of code
      public void TestFindOle()
       const string progID = "AutoCAD.Application.18";
try
catch
try
catch
if (acApp != null)
    AcadDocument AcadDoc = acApp.ActiveDocument;
    acApp.Documents.Open(@"C:\Test\mtext.dwg", Type.Missing, Type.Missing);
        AcadModelSpace AcSpace = AcadDoc.ModelSpace;
        AcadOle AcOle = null;
            //loop through the model space to fill the list of block references
            foreach (AcadEntity AcEnt in AcSpace)
                if (AcEnt is AcadOle)
                    AcOle  = AcEnt as AcadOle;
                  if (AcOle != null)
                      string hand = AcOle.Handle;
                      acApp.ActiveDocument.SendCommand("select " + "(handent " + "\"" + hand + "\"" + ")  ");
                      acApp.ActiveDocument.SendCommand(string.Format("_oleopen  \"{0}\" \r","L"));
~'J'~
1 Kudo
Post 5 of 10
09-04-2012 04:31 AM in reply to: Hallex
Dear Sir,
Thanks very much for your support,
Since my OLE object is in Paper space,
I just modified your coding to paper space only,
everything working well but ole open command is not working,
please see the below coding,
<quote>
if
(acApp != null)
                acApp.Visible =
true;
AcadDocument doc1 = acApp.ActiveDocument;
"D:/test.dwg");
                acApp.Application.Visible =
true;
                acApp.Application.WindowState = Autodesk.AutoCAD.Interop.Common.
AcWindowState.acMax;
                acApp.WindowState = Autodesk.AutoCAD.Interop.Common.
AcadPaperSpace AcSpace = doc1.PaperSpace;
foreach (Autodesk.AutoCAD.Interop.Common.AcadEntity AcEnt in AcSpace)
if (AcEnt is Autodesk.AutoCAD.Interop.Common.AcadOle)
                        AcOle = AcEnt
as Autodesk.AutoCAD.Interop.Common.AcadOle;
if (AcOle != null)
string.Format("_oleopen  \"{0}\" \r", "L"));
MessageBox.Show("tested OK");
<unquote>
best regards,
Micky.
171 Kudos
Post 6 of 10
09-04-2012 05:01 AM in reply to: Micky_1
What is the ole object you've inserted in your drawing?
I'm using Excel for my test
~'J'~
1 Kudo
Post 7 of 10
09-04-2012 06:13 AM in reply to: Micky_1
Dear Sir,
I also using Excel as a OLE object.
programming is working well without any errors.
but only the ole open is not popping up.
regards,
Micky
171 Kudos
Post 8 of 10
09-04-2012 07:19 AM in reply to: Micky_1
Hm, it's strange, can you upload the sample Excel file and drawing with Ole object,
btw I'm using A2010 and Excel 2007 (student release)
~'J'~
1 Kudo
Post 9 of 10
09-04-2012 09:12 AM in reply to: Hallex
Dear Sir,
the file size is around 2 MB, while uploading there is an error.
could you please send me your Email Id so that let me send it to your Email.
best regards,
Micky.
1 Kudo
Post 10 of 10
09-05-2012 01:42 AM in reply to: Hallex
Dear Sir,
Season Greetings,
Sorry to bother you.
since the drawing file size is around 2 MB, there is a error while uploading.
Could you please send me your Email Id to send the drawing file?
I think the problem is in selecting the OLE object,
the program was ignoring the selection,
<quote>
               Autodesk.AutoCAD.Interop.Common.AcadPaperSpace AcSpace = doc1.PaperSpace;
               Autodesk.AutoCAD.Interop.Common.AcadOle AcOle = null;
                //loop through the model space to fill the list of block references                 foreach (Autodesk.AutoCAD.Interop.Common.AcadEntity AcEnt in AcSpace)                 {                     MessageBox.Show("Foreach OK");
                    if (AcEnt is Autodesk.AutoCAD.Interop.Common.AcadOle)                     {                         AcOle = AcEnt as Autodesk.AutoCAD.Interop.Common.AcadOle;                         if (AcOle != null)                         {                             string hand = AcOle.Handle;                             acApp.ActiveDocument.SendCommand("select " + "(handent " + "\"" + hand + "\"" + ")  ");
                            MessageBox.Show("OLE selected..");
                            acApp.ActiveDocument.SendCommand(string.Format("_oleopen  \"{0}\" \r", "L"));                         }                     }                 }
<unquote>
best regards,
Micky.
