.NET
How to call and use the modify properties window from managed Arx
0 REPLIES 0
Message 1 of 1
191 Views, 0 Replies
Hi:
I have a selection set done through vb.net code using the "Editor object" in
the managed Arx i want to modify the items in this selection set through the
modify properties window.How could this be done using managed Arx in vb.net.
I have done it before but with using the send command of the activeX and
passing a selectionset done in the autocad to the command arguments.but i
think there is a better way in arx.
Thanks in advance.
Nermeen Bakr
Project Manager
MCS (Modern Computing Services)
Website: http://www.mcsoil.com
Phone: +2 02 4036520 /+202 4051129
Fax: +2 02 4040503
0 REPLIES 0
”Boost
