.NET
How to calculate real font size?
2 REPLIES 2
pva75
555 Views, 2 Replies
I have point (DBPoint) and I want to draw some text in this point by DrawOverrule.
It works fine:
Point3d textPosition = ....
wd.Geometry.Text(textPosition, point.Normal, Vector3d.XAxis, myText, true, TextStyle);
But how to draw text in two lines?
I can't use MText because it's overruled code (or no?).
So it's required to caclulate real font size and move second line to font vert-size.
Point3d textPosition = .... // first line
wd.Geometry.Text(textPosition, point.Normal, Vector3d.XAxis, myTextLine1, true, TextStyle);
textPosition = textPosition.Add(new Vector3d(???)); // second line
How to do it?
Pavel.
2 REPLIES 2
Hallex
in reply to: pva75
See if this article will helps
http://adndevblog.typepad.com/autocad/2012/05/actual-width-and-height-of-a-text-string.html?cid=6a01...
RichardCammeray
in reply to: Hallex
Hi Pavle,
I have not tested it but to use MText in overrule try something like this in WorldDraw(Drawable d,WorldDraw wd) method
Mtext _mText=new Mtext(do constructor here...);
_mText.WorldDraw(wd);
_mText.Dispose();
Richard
”Boost
