.NET
How to automate loading dlls.
3 REPLIES 3
newArch
277 Views, 3 Replies
Hello there!
Is there any way to automatically load a dotnet dll in AutoCAD.
for ex to put it in startup suit.
thanks and regards.
3 REPLIES 3
in reply to: newArch
You can use AutoCAD's demand loading feature for dotnet projects. Add the
following registry key:
HKEY_LOCAL_MACHINE
SOFTWARE
AutoCAD
R16.2
[Your AutoCAD Version Key]
Applications
[Your app name]
Create the following values under the key:
DESCRIPTION = [A description of your app]
LOADER = [Full path to your assembly DLL]
MANAGED = 1 (dword)
LOADCTRLS = 2 (dword)
Look in the ObjectARX documentation for the values you can use for
LOADCTRLS. The value 2 is used when you want your app to load when AutoCAD
starts up.
Scott
wrote in message news:4966385@discussion.autodesk.com...
Hello there!
thanks and regards.
newArch
Thanks dear Scott McFarlane.
as
an other method is, put it in the acad.lsp in your program directory.
lsp is attached
wkr
Harold van Aarsen
”Boost
