You can use AutoCAD's demand loading feature for dotnet projects. Add the
following registry key:
HKEY_LOCAL_MACHINE
SOFTWARE
AutoCAD
R16.2
[Your AutoCAD Version Key]
Applications
[Your app name]
Create the following values under the key:
DESCRIPTION = [A description of your app]
LOADER = [Full path to your assembly DLL]
MANAGED = 1 (dword)
LOADCTRLS = 2 (dword)
Look in the ObjectARX documentation for the values you can use for
LOADCTRLS. The value 2 is used when you want your app to load when AutoCAD
starts up.
Scott
wrote in message news:4966385@discussion.autodesk.com...
Hello there!
Is there any way to automatically load a dotnet dll in AutoCAD.
for ex to put it in startup suit.
thanks and regards.
