.NET
Valued Contributor
RamanSBV
Message 1 of 6 (194 Views)
How to allow readonly xref files in "Edit Reference In Place" mode.
194 Views, 5 Replies
06-06-2012 11:58 PM
I am working on Xrefs in autocad, I come across one scenario as below,
AutoCAD application is not allowing me, when tring to  "Edit Reference In Place"  mode for readonly xref file. and displaying below dialog box.
Dialog for readonly xref to edit in place mode
Could you any body suggest on this issue.
Raman
Alfred.NESWADBA
Message 2 of 6 (189 Views)
Re: How to allow readonly xref files in "Edit Reference In Place" mode
06-07-2012 12:58 AM in reply to: RamanSBV
you can't edit a file that needs to be saved after edit.
Otherwise XRef-technology would not work, that's mechanism is "show an external (saved) DWG in my current drawing"
If you want to edit the external DWG you can first check it the drawing-file itself or the directory-rights are set to read-only.
Or what's the workflow you are running in your app to get this message?
- alfred -
Alfred NESWADBA
Valued Contributor
RamanSBV
Message 3 of 6 (188 Views)
06-07-2012 01:07 AM in reply to: RamanSBV
Scenario here is,
In Main drawing file, If I am tring to edit(using Edit reference in place) the readonly Xref file, then autoCAD is displaying below shown dailog box.
My Concern here is, Once user click on Edit Reference, I want to turnoff readonly of xref file and allow user to edit the xref file.
Please advice on this.
Raman
Alfred.NESWADBA
Message 4 of 6 (183 Views)
06-07-2012 01:34 AM in reply to: RamanSBV
you can create an eventhandler and check for command-started, if it's a command handling your XRef then handle your readonly-state and on command-ended event you can set back the file-state.
- alfred -
Alfred NESWADBA
Valued Contributor
RamanSBV
Message 5 of 6 (181 Views)
06-07-2012 01:40 AM in reply to: Alfred.NESWADBA
Could you please provide me the code sample on handling this event.
Raman
Alfred.NESWADBA
Message 6 of 6 (176 Views)
06-07-2012 02:00 AM in reply to: RamanSBV
>>>click<<<
- alfred -
Alfred NESWADBA
Autodesk Alert | We are currently working on restoring Previous Version License request access in the Autodesk Subscription Center. If you are a subscription customer and would like to request a Previous Version License, please use this link as a temporary workaround. We apologize for the inconvenience and thank you for your patience.
