I'm having difficulty accessing the CustomizationSection for a particular PartialCUI which I need to return the RibbonTabSource using AutoCAD 2012.
Here's the snippet
var cuiMain = (string)Application.GetSystemVariable("MENUNAME");
var csMain = new CustomizationSection(cuiMain);
//*** This line return null even when the PartialCUI exists? ****
CustomizationSection csPar = csMain.getPartialCUI("myPartialCui");
RibbonRoot rrPar = csPar.MenuGroup.RibbonRoot;
RibbonTabSource tabPar = rrPar.FindTab("RBNU_0001");
Workspace curWs = csMain.getWorkspace(curWorkspace);
csMain.MergeOrAddTabToWorkspace(curWs, tabPar);
if (csMain.IsModified)
csMain.Save();
Application.ReloadAllMenus();
Can you spot where i'm going wrong?
Found a solution by ditching the GetPartialCUI method
var curWorkspace = (string) Application.GetSystemVariable("WSCURRENT");
PartialCuiFileCollection pcfc = csMain.PartialCuiFiles;
string cuiMyPar = null;
foreach (string cui in pcfc)
if (cui.ToLower().Contains("myParCui.cuix"))
cuiMyPar = cui;
if (cuiMyPar == null || !File.Exists(cuiPar)) return;
var csMyPar = new CustomizationSection(cuiPar);
RibbonRoot rrMyPar = csMyPar.MenuGroup.RibbonRoot;
RibbonTabSource tabMyPar = rrMyPar.FindTab("RBNU_0001");
csMain.MergeOrAddTabToWorkspace(curWs, tabMyPar);
csMain.Save();
