.NET
How to add one drawing to another drawing file using autocad interop library
1 REPLY 1
461 Views, 1 Reply
I am using Autocad Interop library. Can any one suggest how i can insert "one.dwg"  in another drawing.
1 REPLY 1
norman.yuan
If you mean insert a drawing as block (A block saved as dwg file) into another drawing, look into
AcadModelSpace/AcadPaperSpace.InsertBlock() method
Norman Yuan
Drive CAD With Code
”Boost
