.NET
How to Add layers to a layergroup
3 REPLIES 3
741 Views, 3 Replies
Is there any one how can help me. How do i add layer to a layergroup.
I know how to create a new layer. But i dont know how to add it to a layergroup.
Can any one provide me a sample on how to achive my goal. Im using C# but a VB.net sample
is also welcome.
Kind regards,
Irvin Berkel Edited by: Irvin on Apr 23, 2009 6:31 AM
3 REPLIES 3
Hello Irvin,
Hope this helps:
'Create Layer Group Filter Containing Layers just created
Private Sub CreateLayerFilter(ByRef db As Database, ByVal filename
As String)
Dim lft As LayerFilterTree = db.LayerFilters
Dim lfc As LayerFilterCollection = lft.Root.NestedFilters
Dim lgt As New LayerGroup
Dim lf As New LayerFilter
Dim t As Transaction = db.TransactionManager.StartTransaction()
Dim lt As LayerTable = t.GetObject(db.LayerTableId, OpenMode.ForWrite)
lgt = New LayerGroup
lgt.Name = filename.ToUpper
'get the layerid for each existing layer and add to layer group
For Each ltrID As ObjectId In lt
lgt.LayerIds.Add(ltrID)
Next
lfc.Add(lgt)
db.LayerFilters = lft
t.Commit()
End Sub
Hi Michael,
Thank's for your code example. Had to converd it to C# but
that was not verry hard. Thanks again.
Kind regards,
Irvin from the Netherlands.
joantopo
Excuse me.
Is it possible get LayerCollection for kind "LayerFilter"?
With the method "LayerIds" we can get LayerCollection for "LayerGroup" but this method doesn´t exist for "LayerFilter".
Thank you.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
”Boost
