does >>>that<<< help?
- alfred -
Thanks for your response......
Could you please me, on getting using
plot style file path.
Raman
it should not be necessary that you assign a plotstyle-path to your CTB as this is defined under options of AutoCAD. AutoCAD knows itself where to find CTB/STB-files. If yours is not in the path for plotstyles you have to copy it into the folder defined to hold plotstyle-files.
- alfred -
Yes, I agree on you.
But I need to export drawing file along with plot style to some other server.
So, I need to know the file path of plot style that is using by drawing file.
Rama
E.g. COM-based you get the path where your plotstyles are stored with that code.
AcadApplication.Preferences.Files.PrinterStyleSheetPath
You can also read >>>that posts<<<
- alfred -
