.NET
How to add a toolbar using cui
2 REPLIES 2
yingzi_tj
592 Views, 2 Replies
there is a problem with my code,when I load this dll,the toolbar‘s name can be fond in the customization dialog,but never shows in the UI(AutoCAD custom WS)。。。。It crush me up。。
[CommandMethod("AddToolBar")]
        public void AddToolBar()
            CustomizationSection cs = new CustomizationSection(
                "C:\\Users\\Administrator\\appdata\\roaming\\autodesk\\autocad 2012 - simplified chinese\\r18.2\\chs\\support\\acad.cuix");
            CAD.Document doc = CAD.Application.DocumentManager.MdiActiveDocument;
            Toolbar newTb = new Toolbar("MyTool", cs.MenuGroup);
            newTb.ToolbarVisible = ToolbarVisible.show;
            foreach (Workspace wk in cs.Workspaces)
                WorkspaceToolbar wkTb = new WorkspaceToolbar(wk, newTb);
                wk.WorkspaceToolbars.Add(wkTb);
                wkTb.Display = 1;
            cs.Save();
i dont no y.........need help························
i am a chinese,know little english.so it is hard for me to find codes of this aspect at this website,can u get me the link of the code?
thanks。谢谢
2 REPLIES 2
Balaji_Ram
in reply to: yingzi_tj
Your code look ok to me.
Does the toolbar appear after switching workspaces manually in AutoCAD ?
Balaji
Developer Technical Services
Autodesk Developer Network
I do not see that this cui-file was loaded into AutoCAD (with command _CUILOAD). Also there is no any toolbar control created in your's code.
Facebook | Twitter | LinkedIn
Expert Elite Member
”Boost
