Hello to all.
I'm new to ObjectARX (.NET).
I would like to add a customized menu in the main toolbar.
Can't find any sample in ObjectARX 2011 samples. And it's really hard to find references.
Could I get some help, please?
Thank you.
@dynamicscope wrote:
...I would like to add a customized menu in the main toolbar...
What is "main toolbar"?
Facebook | Twitter | LinkedIn
Oh. I'm sorry. I meant the menubar where "File" "Edit" "View"... sutff placed.
OK.
1. ObjectARX SDK: samples\dotNet\CuiSamp (but only ObjectARX SDK 2008 and 2009)
2. ActiveX-interface
Following C# (VS 2008) code is what I tried with ObjectARX 2011 SDK & AutoCAD 2011.
When I debug the code it seems it runs fine. It passes throught the if statement without any error.
But I can't find the newly added menu.
Is the code wrong?
[CommandMethod("MyGroup", "My", "MyCommandLocal", CommandFlags.Modal)] public void MyCommand() // This method can have any name { Editor ed = Application.DocumentManager.MdiActiveDocument.Editor; CustomizationSection cs; string mainCuiFile = (string)Application.GetSystemVariable("MENUNAME"); mainCuiFile += ".cuix"; ed.WriteMessage(mainCuiFile); cs = new CustomizationSection(mainCuiFile); if (cs.MenuGroup.PopMenus.IsNameFree("Custom Menu")) { System.Collections.Specialized.StringCollection pmAliases = new System.Collections.Specialized.StringCollection(); PopMenu pm = new PopMenu("Custom Menu", pmAliases, "Custom Menu Tag", cs.MenuGroup); PopMenuItem pmi = new PopMenuItem(pm, -1); pmi.MacroID = "ID_AUGI"; pmi.Name = "Autodesk User Group International"; pmi = new PopMenuItem(pm, -1); pmi = new PopMenuItem(pm, -1); pmi.MacroID = "ID_CustomSafe"; pmi.Name = "Online Developer Center"; foreach (Workspace wk in cs.Workspaces) { WorkspacePopMenu wkpm = new WorkspacePopMenu(wk, pm); wkpm.Display = 1; } } else ed.WriteMessage("Custom Menu already Exists\n"); }
cs.Save(); string flName = cs.CUIFileBaseName; Application.SetSystemVariable("FILEDIA",0); Application.DocumentManager.MdiActiveDocument.SendStringToExecute("_cuiunload " + flName + " ",false,false,false); Application.DocumentManager.MdiActiveDocument.SendStringToExecute("_cuiload " + flName + " filedia 1 ",false,false,false);
If I add the following code, I see my newly added menu "Custom Menu" at the very end of list.
But still can't find it in the GUI menubar.
foreach (Workspace wk in cs.Workspaces) { ed.WriteMessage(wk.Name); foreach (WorkspacePopMenu wsPM in wk.WorkspacePopMenus) { PopMenu pm = cs.getPopMenu(wsPM.PopMenuID); if (pm != null) { ed.WriteMessage(string.Format("\n{0}", pm.Name)); } } }
Thanks a lot for assisting me.
Try:
SendStringToExecute("(menucmd \"Gacad.Help=+MyGroupName.MyPopUpMenuName\") ",false,false,false);
MyGroupName is a name of your's menugroup
MyPopUpMenuName is a name of your's popup-menu.
Unfortunately, the code didn't work for me. 😞
However, I found the following link working.
The code block looks very similar to the one you taught me.
But I am not sure why only the code from the link works.
Anyway, I think my problem is finally solved.
Thank you a lot for your help.
