.NET
How to add a hatch pattern within rectangular boundaries in a block
5 REPLIES 5
2182 Views, 5 Replies
Hi folks,
I am in the process of translating existing VBA code into its equivalent in VB.NET (developing VS Professional 2010 and testing in AutoCAD 2010)
My problem is that I have never done hatching in VB.NET before, and now I am required to hatch a rectangular area (defined by lines) within an AutoCAD block. I have absolutely no idea how to go about accomplishing this task.
To create my block, I am using a DBObjectCollection to store my lines, and then append them to the block definition, creating a reference to see what I just created.
If I were to define a rectangular outline within this block, how can I possibly hatch it?
Any pointers? Suggestions? Thanks in advance...
5 REPLIES 5
Hallex
Here is a code to crate hatch with lines
you have to select two opposite lines and create
polyline to bund the area then apply hatch
Public Sub HatchLines()
        Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim docloc As DocumentLock = doc.LockDocument()
        Dim ed As Editor = doc.Editor
        Dim db As Database = doc.Database
        Dim tr As Transaction = db.TransactionManager.StartTransaction()
        Using docloc
            Using tr
                'ed.StartUserInteraction(Me)'<-- just in case you using this code from form button
                Dim peo As PromptEntityOptions = New PromptEntityOptions(vbCr & "Select first line: ")
                peo.SetRejectMessage(vbCr & "Select line only: ")
                peo.AddAllowedClass(GetType(Line), True)
                Dim pres As PromptEntityResult = ed.GetEntity(peo)
                If (pres.Status <> PromptStatus.OK) Then
                    Return
                Dim ent As Entity = CType(tr.GetObject(pres.ObjectId, OpenMode.ForRead), Entity)
                Dim line1 As Line = DirectCast(ent, Line)
                If line1 Is Nothing Then
                    Return
                peo.Message = vbCr & "Select second line: "
                pres = ed.GetEntity(peo)
                    Return
                ent = CType(tr.GetObject(pres.ObjectId, OpenMode.ForRead), Entity)
                Dim line2 As Line = DirectCast(ent, Line)
                If line2 Is Nothing Then
                    Return
                Dim sp1 As Point3d = line1.StartPoint
                Dim ep1 As Point3d = line1.EndPoint
                Dim sp2 As Point3d = line2.StartPoint
                Dim ep2 As Point3d = line2.EndPoint
                'check for line directions
                If Math.Abs(line1.Angle - line2.Angle) >= Math.PI Then
                    'swap points if the second line has an opposite direction
                    Dim tmp As Point3d = sp1
                    sp1 = ep1
                    ep1 = tmp
                Dim btr As BlockTableRecord = CType(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
                Dim pl As Polyline = New Polyline()
                pl.AddVertexAt(0, New Point2d(sp1.X, sp1.Y), 0, 0, 0)
                pl.AddVertexAt(1, New Point2d(ep1.X, ep1.Y), 0, 0, 0)
                pl.AddVertexAt(2, New Point2d(ep2.X, ep2.Y), 0, 0, 0)
                pl.AddVertexAt(3, New Point2d(sp2.X, sp2.Y), 0, 0, 0)
                pl.Closed = True
                btr.AppendEntity(pl)
                tr.AddNewlyCreatedDBObject(pl, True)
                Dim ids As ObjectIdCollection = New ObjectIdCollection
                ids.Add(pl.ObjectId)
                db.TransactionManager.QueueForGraphicsFlush()
                Dim hatch As Hatch = New Hatch()
                hatch.HatchStyle = HatchStyle.Normal
                hatch.PatternScale = 60.0 '<--change hatch scale to suit
                hatch.PatternAngle = 0.0
                hatch.SetHatchPattern(HatchPatternType.PreDefined, "ANSI37") '<--change pattern name to suit
                hatch.AppendLoop(HatchLoopTypes.Outermost, ids)
                hatch.Associative = False
                hatch.EvaluateHatch(False)
                btr.SetObjectIdsInFlux()
                btr.AppendEntity(hatch)
                tr.AddNewlyCreatedDBObject(hatch, True)
                pl.Erase()
                pl.Dispose()
                ed.Regen()
                tr.Commit()
            End Using
        End Using
    End Sub
 You then go expand this code to your needs
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
in reply to: Hallex
This is very good... Thanks so much, Hallex, much appreciated.
Hallex
Glad to help
Happy vbneting,
Cheers 🙂
smx_khang
in reply to: Hallex
@Hallex
Thanks for your sample. It is very helpful to me.
However, I have a question. Can you explain to me why you are using below API?
 I can see that hatch is generated with or without that line... Can you tell me what is `SetObjectIdsInFlux` used for?
kdub_nz
@smx_khang
perhaps :
https://help.autodesk.com/view/OARX/2022/ENU/?guid=OARX-ManagedRefGuide-Autodesk_AutoCAD_DatabaseSer...
// Called Kerry in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>;      another  Swamper
”Boost
