.NET
.NET
Valued Contributor
1 Kudo
Post 1 of 4
How to add a hatch pattern within rectangular boundaries in a block
799 Views, 3 Replies
02-28-2013 09:55 AM
Hi folks,
I am in the process of translating existing VBA code into its equivalent in VB.NET (developing VS Professional 2010 and testing in AutoCAD 2010)
My problem is that I have never done hatching in VB.NET before, and now I am required to hatch a rectangular area (defined by lines) within an AutoCAD block. I have absolutely no idea how to go about accomplishing this task.
To create my block, I am using a DBObjectCollection to store my lines, and then append them to the block definition, creating a reference to see what I just created.
If I were to define a rectangular outline within this block, how can I possibly hatch it?
Any pointers? Suggestions? Thanks in advance...
Here is a code to crate hatch with lines
you have to select two opposite lines and create
polyline to bund the area then apply hatch
Public Sub HatchLines()
Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim docloc As DocumentLock = doc.LockDocument()
Dim ed As Editor = doc.Editor
Dim db As Database = doc.Database
Dim tr As Transaction = db.TransactionManager.StartTransaction()
Using docloc
Using tr
'ed.StartUserInteraction(Me)'<-- just in case you using this code from form button
Dim peo As PromptEntityOptions = New PromptEntityOptions(vbCr & "Select first line: ")
peo.SetRejectMessage(vbCr & "Select line only: ")
peo.AddAllowedClass(GetType(Line), True)
Dim pres As PromptEntityResult = ed.GetEntity(peo)
If (pres.Status <> PromptStatus.OK) Then
Return
End If
Dim ent As Entity = CType(tr.GetObject(pres.ObjectId, OpenMode.ForRead), Entity)
Dim line1 As Line = DirectCast(ent, Line)
If line1 Is Nothing Then
Return
End If
peo.Message = vbCr & "Select second line: "
pres = ed.GetEntity(peo)
Return
End If
ent = CType(tr.GetObject(pres.ObjectId, OpenMode.ForRead), Entity)
Dim line2 As Line = DirectCast(ent, Line)
If line2 Is Nothing Then
Return
End If
Dim sp1 As Point3d = line1.StartPoint
Dim ep1 As Point3d = line1.EndPoint
Dim sp2 As Point3d = line2.StartPoint
Dim ep2 As Point3d = line2.EndPoint
'check for line directions
If Math.Abs(line1.Angle - line2.Angle) >= Math.PI Then
'swap points if the second line has an opposite direction
Dim tmp As Point3d = sp1
sp1 = ep1
ep1 = tmp
End If
Dim btr As BlockTableRecord = CType(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
Dim pl As Polyline = New Polyline()
pl.AddVertexAt(0, New Point2d(sp1.X, sp1.Y), 0, 0, 0)
pl.AddVertexAt(1, New Point2d(ep1.X, ep1.Y), 0, 0, 0)
pl.AddVertexAt(2, New Point2d(ep2.X, ep2.Y), 0, 0, 0)
pl.AddVertexAt(3, New Point2d(sp2.X, sp2.Y), 0, 0, 0)
pl.Closed = True
btr.AppendEntity(pl)
tr.AddNewlyCreatedDBObject(pl, True)
Dim ids As ObjectIdCollection = New ObjectIdCollection
ids.Add(pl.ObjectId)
db.TransactionManager.QueueForGraphicsFlush()
Dim hatch As Hatch = New Hatch()
hatch.HatchStyle = HatchStyle.Normal
hatch.PatternScale = 60.0 '<--change hatch scale to suit
hatch.PatternAngle = 0.0
hatch.SetHatchPattern(HatchPatternType.PreDefined, "ANSI37") '<--change pattern name to suit
hatch.AppendLoop(HatchLoopTypes.Outermost, ids)
hatch.Associative = False
hatch.EvaluateHatch(False)
btr.SetObjectIdsInFlux()
btr.AppendEntity(hatch)
tr.AddNewlyCreatedDBObject(hatch, True)
pl.Erase()
pl.Dispose()
ed.Regen()
tr.Commit()
End Using
End Using
End Sub
 You then go expand this code to your needs
171 Kudos
Post 2 of 4
Re: How to add a hatch pattern within rectangular boundaries in a block
02-28-2013 12:28 PM in reply to: mindofcat
        Using docloc
            Using tr
                    Return
                End If
                    Return
                End If
                    Return
                End If
                    Return
                End If
                    sp1 = ep1
                    ep1 = tmp
                End If
                pl.Closed = True
                pl.Erase()
                pl.Dispose()
                ed.Regen()
                tr.Commit()
            End Using
        End Using
    End Sub
Valued Contributor
1 Kudo
Post 3 of 4
02-28-2013 12:32 PM in reply to: Hallex
This is very good... Thanks so much, Hallex, much appreciated.
171 Kudos
Post 4 of 4
02-28-2013 12:59 PM in reply to: mindofcat
Glad to help
Happy vbneting,
Cheers :smileyhappy:
