.NET
Amrit.shr
Message 1 of 8 (2,735 Views)
how to access AutoCAD 2012 from Vb.net Standard Exe
2735 Views, 7 Replies
03-08-2012 07:09 AM
hi
is that possible to access AutoCAD 2012 from VB.net Standard Exe
i am using vb.net 2010
i try to load AcDbMgd.dll and AcMgd every time i compile it give error in "Imports
Autodesk.AutoCAD.ApplicationServices"
is there any example for read and write current open drawing in AutoCAD from .net Standard Exe.
Thanks in advance.
Amrit
arcticad
Message 2 of 8 (2,729 Views)
Re: how to access AutoCAD 2012 from Vb.net Standard Exe
03-08-2012 07:41 AM in reply to: Amrit.shr
http://through-the-interface.typepad.com/through_the_interface/2006/07/debugging_using.html
(defun botsbuildbots() (botsbuildbots))
Amrit.shr
Message 3 of 8 (2,725 Views)
03-08-2012 07:59 AM in reply to: arcticad
i don't understand
arcticad
Message 4 of 8 (2,722 Views)
03-08-2012 08:09 AM in reply to: Amrit.shr
Sorry I read your question wrong.
acDbMgd.dll and AcMgd are only for internal use within Autocad. They can't be used by an outside EXE.
Get a reference to COM Autocad 2012 Type Library
Imports System
Imports System.Runtime.InteropServices
Imports Autodesk.AutoCAD.Interop
Public Class ComCode
    Public Sub runme()
        Const progID As String = "AutoCAD.Application.18"
        Dim acApp As AcadApplication = Nothing
        Try
            acApp = DirectCast(Marshal.GetActiveObject(progID), AcadApplication)
        Catch ex As Exception
            Try
                Dim acType As Type = Type.GetTypeFromProgID(progID)
                acApp = DirectCast(Activator.CreateInstance(acType, True), AcadApplication)
            Catch ex2 As Exception
                MessageBox.Show("Cannot create object of type """ & progID & """")
            End Try
        End Try
        If acApp IsNot Nothing Then
            ' By the time this is reached AutoCAD is fully
            ' functional and can be interacted with through code
        End If
    End Sub
End Clas
Amrit.shr
Message 5 of 8 (2,714 Views)
03-08-2012 08:32 AM in reply to: arcticad
hi arcticad
thanks for reply
it look like it is connect with autocad. but how to draw object and how to select object on it. could you please give little  hints.
thnaks
arcticad
Message 6 of 8 (2,701 Views)
03-08-2012 09:31 AM in reply to: Amrit.shr
   Sub dwgAddCircle(ByVal acadApp As Autodesk.AutoCAD.Interop.AcadApplication)
        Dim doc As AcadDocument = acadApp.ActiveDocument
        Dim pt(2) As Double
        pt(0) = 0
        pt(1) = 0
        pt(2) = 0
        doc.ModelSpace.AddCircle(pt, 10)
    End Sub
    Sub dwgReSave(ByVal acadApp As Autodesk.AutoCAD.Interop.AcadApplication, ByVal strFileName As String)
        Dim acadDBX As Object = acadApp.GetInterfaceObject("ObjectDBX.AxDbDocument.18")
        If FileExists(strFileName) Then
            If Not InUse(strFileName) Then
                Try
                    acadDBX.Open(strFileName)
                    acadDBX.saveas(strFileName)
                    acadDBX = Nothing
                    System.Runtime.InteropServices.Marshal.ReleaseComObject(acadApp)
                    GC.Collect()
                    GC.WaitForPendingFinalizers()
                End Try
            End If
        End If
    End Sub
    Public Function InUse(ByVal sFile As String) As Boolean
        If System.IO.File.Exists(sFile) Then
            Try
                Dim F As Short = FreeFile()
                FileOpen(F, sFile, OpenMode.Binary, OpenAccess.ReadWrite, OpenShare.LockReadWrite)
                FileClose(F)
            Catch
                Return True
            End Try
        End If
    End Function
    Public Function FileExists(ByVal FileFullPath As String) _
As Boolean
        Dim f As New IO.FileInfo(FileFullPath)
        Return f.Exists
    End Function
Amrit.shr
Message 7 of 8 (2,662 Views)
03-09-2012 08:26 AM in reply to: Amrit.shr
it come error
Unable to cast COM object of type 'System.__ComObject' to interface type 'Autodesk.AutoCAD.Interop.Common.IAcadModelSpace'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{C60BC8AF-58DA-4866-859D-22A7F61411DE}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
in line
Amrit.shr
Message 8 of 8 (2,643 Views)
03-11-2012 02:32 PM in reply to: Amrit.shr
hi Arcticad
your code work while i change compiler  to 3.5. and when i try to use 4 it give error on draw.
Thanks you
Could any one suggest me what need more in code to draw from exe to autocad while i set to compile option in .net framework 4.
