Hope somebody could help me with this.
I need to lock user to a certain angle when prompting ot pick points. in PrompPointOptions. Right now I am faking and useing
SendStringToexecute . But I really like to use a way to do in net. Here is My Code. Thanks In Advance.
Function vns_Getpoint_with_Base_Angle_Given(ByVal msg As String, ByVal baseP As Point3d, ByVal angle As Double, ByRef P As Point3d) As Integer Dim Mydwg As Document = Application.DocumentManager.MdiActiveDocument Dim Myed As Editor = Mydwg.Editor Dim ppo As PromptPointOptions = New PromptPointOptions("") Mydwg.SendStringToExecute("<" & Trim(angle * 180 / Math.PI.ToString) & " ", False, False, False) ppo.Message = msg ppo.UseBasePoint = True ppo.UseDashedLine = True ppo.BasePoint = baseP ppo.AllowNone = True Dim ppr As PromptPointResult = Myed.GetPoint(ppo) P = ppr.Value If ppr.Status = PromptStatus.OK Then Return 1 End If End Function
Solved by chiefbraincloud. Go to Solution.
I have used a variety of methods to accomplish this on different tasks. Most of them won't work with GetPoint though, so the simplest way I can suggest is to set the cursor angle (the SNAPANG system variable) to the angle you want and set ORTHOMODE to 1. Of course the user can turn ortho off during the getpoint.
If you really want to force the angle, without the user having any way to stop you, then you'll need to create your own jig and override the point in the Update routine.
Chief , Again you saved me . I don't know how to thank you. Your solution is better than mine. and I am not gonna mess with
Jig which I never understand it. But now I am fine and take your way.
Cheers,
Chief , Noram wrote this. it is working . But too long. Anyways I am using yours in my codes. Just for your info and all help I got from you. Thanks.
Public Class DragCommand <CommandMethod("AngledDrag")> _ Public Sub RunThisMethod() Dim dwg As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument Dim drag As New AngledDrag(dwg) Try If drag.DragAtAngle() Then GenerateLine(dwg, drag.StartPoint, drag.EndPoint) dwg.Editor.WriteMessage(vbLf & "MyCommand executed.") End If Catch ex As Autodesk.AutoCAD.Runtime.Exception dwg.Editor.WriteMessage(vbLf & "Error: {0}" & vbLf, ex.Message) End Try End Sub Private Shared Sub GenerateLine(ByVal dwg As Document, ByVal startPt As Point3d, ByVal endPt As Point3d) Using tran As Transaction = dwg.Database.TransactionManager.StartTransaction() Dim br As BlockTableRecord = DirectCast(tran.GetObject(dwg.Database.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord) Dim line As New Line(startPt, endPt) line.SetDatabaseDefaults(dwg.Database) br.AppendEntity(line) tran.AddNewlyCreatedDBObject(line, True) tran.Commit() End Using End Sub End Class Public Class AngledDrag Private _dwg As Document Private _db As Database Private _editor As Editor Private _startPoint As New Point3d(0.0, 0.0, 0.0) Private _endPoint As New Point3d(0.0, 0.0, 0.0) Private _dragAngle As Double = 45.0 Private _dragLine As Line = Nothing Private _colorIndex As Integer = 1 Public Sub New(ByVal dwg As Document) _dwg = dwg _db = dwg.Database _editor = dwg.Editor End Sub Public ReadOnly Property StartPoint() As Point3d Get Return _startPoint End Get End Property Public ReadOnly Property EndPoint() As Point3d Get Return _endPoint End Get End Property Public Function DragAtAngle() As Boolean _endPoint = _startPoint AddHandler _editor.PointMonitor, New PointMonitorEventHandler(AddressOf Editor_PointMonitor) Try 'Get end point If GetEndPoint() Then Return True Else Return False End If Finally ClearTransientGraphics() RemoveHandler _editor.PointMonitor, AddressOf Editor_PointMonitor End Try End Function Private Sub Editor_PointMonitor(ByVal sender As Object, ByVal e As PointMonitorEventArgs) DrawDragLine(e.Context.RawPoint) If _dragLine IsNot Nothing Then e.AppendToolTipText("Angle: " + _dragAngle.ToString() + vbLf & "Length: " + _dragLine.Length.ToString()) Else e.AppendToolTipText("") End If End Sub Private Sub DrawDragLine(ByVal mousePoint As Point3d) ClearTransientGraphics() Dim pt As Point3d = CalculateEndPoint(mousePoint) _dragLine = New Line(_startPoint, pt) _dragLine.SetDatabaseDefaults(_db) _dragLine.ColorIndex = _colorIndex Dim col As New IntegerCollection() TransientManager.CurrentTransientManager.AddTransient(_dragLine, TransientDrawingMode.Highlight, 128, col) 'whenever the dragged line updated, reset _endPoint _endPoint = pt End Sub Private Sub ClearTransientGraphics() If _dragLine IsNot Nothing Then Dim col As New IntegerCollection() TransientManager.CurrentTransientManager.EraseTransient(_dragLine, col) _dragLine.Dispose() _dragLine = Nothing End If End Sub Private Function CalculateEndPoint(ByVal mousePoint As Point3d) As Point3d Dim pt As Point3d = mousePoint If _dragAngle <= 90.0 OrElse _dragAngle >= 270.0 Then If mousePoint.X <= _startPoint.X Then pt = _startPoint Else If _dragAngle <= 45.0 OrElse _dragAngle >= 315.0 Then Dim y As Double = (mousePoint.X - _startPoint.X) * Math.Tan(_dragAngle * Math.PI / 180) pt = New Point3d(mousePoint.X, _startPoint.Y + y, 0.0) Else If _dragAngle > 45.0 AndAlso _dragAngle <= 90.0 Then If mousePoint.Y < _startPoint.Y Then pt = _startPoint Else Dim x As Double = (mousePoint.Y - _startPoint.Y) / Math.Tan(_dragAngle * Math.PI / 180) pt = New Point3d(_startPoint.X + x, mousePoint.Y, 0.0) End If Else If mousePoint.Y > _startPoint.Y Then pt = _startPoint Else Dim x As Double = (mousePoint.Y - _startPoint.Y) / Math.Tan(_dragAngle * Math.PI / 180) pt = New Point3d(_startPoint.X + x, mousePoint.Y, 0.0) End If End If End If Return pt End If End If If _dragAngle >= 90.0 AndAlso _dragAngle <= 270.0 Then If mousePoint.X >= _startPoint.X Then pt = _startPoint Else If _dragAngle >= 135.0 AndAlso _dragAngle <= 225.0 Then Dim y As Double = (mousePoint.X - _startPoint.X) * Math.Tan(_dragAngle * Math.PI / 180) pt = New Point3d(mousePoint.X, _startPoint.Y + y, 0.0) Else If _dragAngle >= 90.0 AndAlso _dragAngle < 135.0 Then If mousePoint.Y <= _startPoint.Y Then pt = _startPoint Else Dim x As Double = (mousePoint.Y - _startPoint.Y) / Math.Tan(_dragAngle * Math.PI / 180) pt = New Point3d(_startPoint.X + x, mousePoint.Y, 0.0) End If Else If mousePoint.Y >= _startPoint.Y Then pt = _startPoint Else Dim x As Double = (mousePoint.Y - _startPoint.Y) / Math.Tan(_dragAngle * Math.PI / 180) pt = New Point3d(_startPoint.X + x, mousePoint.Y, 0.0) End If End If End If Return pt End If End If Return pt End Function Private Function GetEndPoint() As Boolean 'endPoint = new Point3d(); Dim go As Boolean = True Dim picked As Boolean = False While go Dim opt As New PromptPointOptions(vbLf & "Pick point:") 'opt.BasePoint = _startPoint; 'opt.UseBasePoint = true; opt.Keywords.Add("Start point") opt.Keywords.Add("Angle") opt.Keywords.Add("End point") opt.Keywords.Add("eXit") opt.Keywords.[Default] = "End point" opt.AppendKeywordsToMessage = True opt.AllowArbitraryInput = False opt.AllowNone = False Dim res As PromptPointResult = _editor.GetPoint(opt) If res.Status = PromptStatus.Cancel Then go = False Else Select Case res.Status Case PromptStatus.Keyword '_editor.WriteMessage("\n" + res.StringResult); If res.StringResult.StartsWith("Start") Then SetStartPoint() go = True End If If res.StringResult.StartsWith("Angle") Then SetAngle() go = True End If If res.StringResult.StartsWith("eXit") Then go = False End If Exit Select Case PromptStatus.OK 'endPoint = res.Value; picked = True go = False Exit Select Case Else go = True Exit Select End Select End If End While Return picked End Function Private Sub SetStartPoint() ClearTransientGraphics() RemoveHandler _editor.PointMonitor, AddressOf Editor_PointMonitor Dim opt As New PromptPointOptions(vbLf & "Start point:") Dim res As PromptPointResult = _editor.GetPoint(opt) If res.Status = PromptStatus.OK Then _startPoint = res.Value End If AddHandler _editor.PointMonitor, New PointMonitorEventHandler(AddressOf Editor_PointMonitor) End Sub Private Sub SetAngle() ClearTransientGraphics() RemoveHandler _editor.PointMonitor, AddressOf Editor_PointMonitor Dim opt As New PromptDoubleOptions(vbLf & "Enter drag-angle in degree [" + _dragAngle.ToString() + "]: ") opt.AllowNegative = False opt.AllowZero = True opt.AllowNone = True Dim res As PromptDoubleResult = _editor.GetDouble(opt) If res.Status = PromptStatus.OK Then _dragAngle = res.Value If _dragAngle > 360.0 Then _dragAngle -= 360.0 End If End If AddHandler _editor.PointMonitor, New PointMonitorEventHandler(AddressOf Editor_PointMonitor) End Sub End Class
