.NET
*GPaolo
Message 1 of 5 (258 Views)
How i can use "UserConfigurationManager"
258 Views, 4 Replies
02-06-2007 05:48 AM
I need to import or export the current profile in a file named .ARG
I think that the class that make this is :
Autodesk.autocad.application.UserConfigurationManager.OpenCurrentProfile()
but i don't find some example or explanation.
Dim i As Autodesk.AutoCAD.ApplicationServices.IConfigurationSection
i =
Autodesk.AutoCAD.ApplicationServices.Application.UserConfigurationManager.Op
enCurrentProfile()
thanks in advance
GPaolo
*Kerry Brown
Message 2 of 5 (258 Views)
Re: How i can use "UserConfigurationManager"
02-07-2007 12:35 PM in reply to: *GPaolo
I think you may have to use Com interop AcadPreferences
something like
acadPref.Profiles.ImportProfile("TESTPROFILE", "c:\\TESTPROFILE.ARG", True)
If you find a way in the NET API from the wrapped Library I'd like to know.
/// kwb
"GPaolo" wrote in message
news:5476316@discussion.autodesk.com...
i =
enCurrentProfile()
thanks in advance
GPaolo
*GPaolo
Message 3 of 5 (258 Views)
02-07-2007 10:50 PM in reply to: *GPaolo
I already use Com Interop
something like
I want make a complete unmanaged application.
Bye.
"Kerry Brown" ha scritto nel messaggio
news:5478747@discussion.autodesk.com...
something like
/// kwb
i =
enCurrentProfile()
thanks in advance
GPaolo
*Tony Tanzillo
Message 4 of 5 (258 Views)
02-11-2007 12:50 AM in reply to: *GPaolo
I'm pretty sure that the COM implementation is
just reading the registry directly. You can do that
yourself, althought its obviously more work than
just using COM.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
"GPaolo" wrote in message news:5479224@discussion.autodesk.com...
something like
Bye.
something like
/// kwb
i =
enCurrentProfile()
thanks in advance
GPaolo
*Expert Elite*
Sinc
Message 5 of 5 (258 Views)
02-19-2007 11:11 PM in reply to: *GPaolo
The UserConfigurationManager provides access to specific locations in the registry. Access it like this:
UserConfigurationManager ucm = Autodesk.AutoCAD.ApplicationServices.Application.UserConfigurationManager;
IConfigurationSection regbase = ucm.OpenGlobalSection();
For OpenGlobalSection(), regbase is the primary Civil-3D entry in HKCU/Software/Autodesk.
Sinc
Announcements
Need installation help?
