.NET
How i can use "UserConfigurationManager"
4 REPLIES 4
595 Views, 4 Replies
I need to import or export the current profile in a file named .ARG
I think that the class that make this is :
Autodesk.autocad.application.UserConfigurationManager.OpenCurrentProfile()
but i don't find some example or explanation.
Dim i As Autodesk.AutoCAD.ApplicationServices.IConfigurationSection
i =
Autodesk.AutoCAD.ApplicationServices.Application.UserConfigurationManager.Op
enCurrentProfile()
thanks in advance
GPaolo
4 REPLIES 4
I think you may have to use Com interop AcadPreferences
something like
acadPref.Profiles.ImportProfile("TESTPROFILE", "c:\\TESTPROFILE.ARG", True)
If you find a way in the NET API from the wrapped Library I'd like to know.
/// kwb
"GPaolo" wrote in message
news:5476316@discussion.autodesk.com...
i =
enCurrentProfile()
thanks in advance
GPaolo
I already use Com Interop
something like
I want make a complete unmanaged application.
Bye.
"Kerry Brown" ha scritto nel messaggio
news:5478747@discussion.autodesk.com...
something like
/// kwb
i =
enCurrentProfile()
thanks in advance
GPaolo
I'm pretty sure that the COM implementation is
just reading the registry directly. You can do that
yourself, althought its obviously more work than
just using COM.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
"GPaolo" wrote in message news:5479224@discussion.autodesk.com...
something like
Bye.
something like
/// kwb
i =
enCurrentProfile()
thanks in advance
GPaolo
Sinc
The UserConfigurationManager provides access to specific locations in the registry. Access it like this:
UserConfigurationManager ucm = Autodesk.AutoCAD.ApplicationServices.Application.UserConfigurationManager;
IConfigurationSection regbase = ucm.OpenGlobalSection();
For OpenGlobalSection(), regbase is the primary Civil-3D entry in HKCU/Software/Autodesk.
Sinc
”Boost
