.NET
How do you get the Entity Name?
2 REPLIES 2
stuartshaw
1452 Views, 2 Replies
Does anyone know how to get the entity name (code -01) from an entity. I am using vb.net 2005 with AuotCAD 2007.
I also am using AutoCAD Intent that returns the entity name but I need to get to the handle or ObjectId.
2 REPLIES 2
in reply to: stuartshaw
Autodesk.autocad.windows.linetypedialog.linetype.handle
ahmed.felix
For comparison purposes you could simply use TypeOf.
If TypeOf entEntity Is Line Then
' Some code
Note that Autodesk.AutoCAD.DatabaseServices must be imported
to use the Line type directly.
If you want the name of the entity without comparison then you could do this:
Dim strName as String
strName = entEntity.GetType.ToString
That will return something like "Autodesk.AutoCad.DatabaseServices.Line"
Dim strTypes() As String
strTypes= entEntity.GetType.ToString.Split(".")
strName = strTypes(strTypes.GetUpperBound(0))
That will return just "Line"
”Boost
