.NET
How do I get if I run autocad vanilla or autocad civil3D
4 REPLIES 4
dancalgary
524 Views, 4 Replies
I created 2 dll's
One for autocad  the other one for civil
I created another dll that loads using
Reflection.Assembly.LoadFrom("file")
the dlls into autocad at startup
I want to be able to detect if the productID is civil to be able to load the civil3d dll.
Can somebody tell me how to detect this?
4 REPLIES 4
hgasty1001
in reply to: dancalgary
Check the "PRODUCT" system variable.
Gaston Nunez
dancalgary
in reply to: hgasty1001
product variable for both autocad and civil3d has the same content:
PRODUCT = "AutoCAD" (read only)
I need something to be able to see if is civil3d or not.
hgasty1001
Oops, It seems you have to extract that info from the registry, this link may hel you: registry Product Info
Gaston Nunez
dancalgary
thanks this helped
I used
Autodesk.AutoCAD.Runtime.SystemObjects.DynamicLinker.ProductKey = "Software\Autodesk\AutoCAD\R18.2\ACAD-a000:409"
”Boost
