.NET
How do I copy or clone a BlockRef from an xref into the topmost parent?
3 REPLIES 3
McSwiller
632 Views, 3 Replies
I'd like to copy some blockreferences from an xref into the uppermost parent drawing. I've tried using DeepCloneObjects and gotten an eWrongDatabase message, and I've tried WblockCloneObjects and gotten an eInvalidOwnerObject error.
In this instance, I've tried getting a handle to the xref db (sourceDb) through the XrefGraphNode object. The objId collection was built by enumerating through the host drawing block table however, and drilling into the xref from there, is that what I'm doing wrong?:
Dim mapping As IdMapping = sourceDb.WblockCloneObjects(oidColl, hostDb.BlockTableId, DuplicateRecordCloning.Replace, False)
Any other suggestions?
Thanks for the time,
Mike
3 REPLIES 3
chiefbraincloud
in reply to: McSwiller
If you haven't seen it, you should check out the post here: //through-the-interface.typepad.com/through_the_interface/2006/08/import_blocks_f.html
I took the http: off the front because this forum always screws up and adds a %20 character where it doesn't belong when you paste a link, so just copy it to your address bar and put the http: back on.
What it should show you is the proper way to set up the WBlockClone. When I got the eWrongDatabase error, it just about drove me crazy until I looked closer at the example and found that the TransactionManager used to create the transaction for the WblockClone had to come from the Source Database, where the objects are being cloned from.
My code is like the post, using a "side database" , not an Xref, so I'm not sure about any complications there.
Unless you want to offer a prize to the first person
that
can correctly guess what the relevant code you didn't
show is doing, include it in your post and someone
can
then give you some help.
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000
through 2009
href="http://www.acadxtabs.com">http://www.acadxtabs.com
I'd
error. In this instance, I've tried getting a handle to the xref db (sourceDb)
the xref from there, is that what I'm doing wrong?: Dim mapping As IdMapping =
DuplicateRecordCloning.Replace, False) Any other suggestions? Thanks for the
time, Mike
McSwiller
Thank you chiefbraincloud - It looks like I'm going to have to pursue a method more like Kean's after all. That is, to read in an external file (the xref), and then get my objectIdCollection from there.
”Boost
