.NET
how datagridview to show data in a dwg?
5 REPLIES 5
699 Views, 5 Replies
5 REPLIES 5
augusto.goncalves
Your question is not very clear...
It seems that the DWG image you share was produced with a Excel (or similar) table, which are usually created with a OLE object. If that is the case, unfortunately we don't have much APIs for it...
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
in reply to: augusto.goncalves
thank you;
yes my goal to read the data in DWG
example dwg file :Drawing1.dwg
augusto.goncalves
Indeed this is an OLE object and there is no API to manipulate (i.e. extract its data)
Augusto Goncalves
searched but did not find any.
can you help me ?
arcticad
http://forums.autodesk.com/t5/NET/I-want-to-read-data-from-a-DWG-excel-file-using-C/m-p/3927350/high...
This might help
(defun botsbuildbots() (botsbuildbots))
”Boost
