.NET
How could I prompt a line entity from the user?
1 REPLY 1
dynamicscope
353 Views, 1 Reply
How could I prompt a "two points" line entity from the user?
Something similar to " Editor.GetPoint() " ??
I was trying to use Editor.GetPoint() method two times. But this option does not show the preview of a line.
I also tried a combination of
doc.SendStringToExecute("line ");
db.ObjectAppended += new ObjectEventHandler(LineAppended);
but this option triggers LineAppended event handler as soon as I create the first point of a line. So it does not help.
Would there be a better way?
1 REPLY 1
Jeff_M
in reply to: dynamicscope
Look at the PromptPointOptions. It allows you to specify a Basepoint, and whether to use it, so you get the drag line when picking a second point.
”Boost
