How change text width in table cell using autocad .net api C#?
I create Table using Autocad .net api C#.
var table = new Table();
In single text(class DBText), change text width of the property - WidthFactor.
hgasty1001
Table.Cells(i,j).TextStyleId=Id_Of_The_TextStyle_With_Needed_WidthFactor should work.
Gaston Nunez
chiefbraincloud
Use Formatting in the contents like Mtext.
"{\W0.5;Text Width = 0.5}"
Thanks!!! it works perfectly!!!!
kerry_w_brown
Since you answered your own post ... which solution worked for you ??
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
