.NET
.NET
Member
0 Kudos
Post 1 of 5
How change text width in table cell using autocad .net api C#?
1384 Views, 4 Replies
07-01-2012 02:47 PM
I create Table using Autocad .net api C#.
var table = new Table();
In single text(class DBText), change text width of the property - WidthFactor.
Use Formatting in the contents like Mtext.
"{\W0.5;Text Width = 0.5}"
Distinguished Mentor
91 Kudos
Post 2 of 5
Re: How change text width in table cell using autocad .net api C#?
07-01-2012 03:16 PM in reply to: 1854656984
Table.Cells(i,j).TextStyleId=Id_Of_The_TextStyle_With_Needed_WidthFactor should work.
Gaston Nunez
54 Kudos
Post 3 of 5
07-02-2012 10:14 AM in reply to: gasty1001
Member
0 Kudos
Post 4 of 5
07-03-2012 06:46 AM in reply to: 1854656984
Thanks!!! it works perfectly!!!!
Valued Mentor
22 Kudos
Post 5 of 5
07-03-2012 05:19 PM in reply to: 1854656984
Since you answered your own post ... which solution worked for you ??
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>;      another  Swamper
