I create Table using Autocad .net api C#.
var table = new Table();
In single text(class DBText), change text width of the property - WidthFactor.
How change text width in table cell using autocad .net api C#?
Solved by chiefbraincloud. Go to Solution.
Table.Cells(i,j).TextStyleId=Id_Of_The_TextStyle_With_Needed_WidthFactor should work.
Gaston Nunez
Use Formatting in the contents like Mtext.
"{\W0.5;Text Width = 0.5}"
@1854656984 wrote:Thanks!!! it works perfectly!!!!
Since you answered your own post ... which solution worked for you ??
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>; another Swamper
