.NET
Valued Contributor
kevinsir
Message 1 of 19 (485 Views)
How can I use a graphic ellipse with text together?
485 Views, 18 Replies
03-15-2013 08:24 PM
Hello, everyone
I want to create a new order. when  using the order,It will create a  ellipse and  a DTEXT .I mean the ellipse and the DTEXT are a whole. when move the ellipse the DTEXT will alse move.However, users can  edit the  DTEXT.
Someone who can give  me some solution? Thanks very much!
Hi Kevin,
Do you want to create the block with one attribute inside the ellipse?
I am sorry that I mean the AttributeReference! Now I have find the 'AttributeCollection' Property of BlockReference which can access the Attribute. However, I have not find any Property of BlockReference to access the ellipse. Does it have any way to access it and set it visible or invisible?
kevinsir wrote:
...However, I have not find any Property of BlockReference to access the ellipse. Does it have any way to access it and set it visible or invisible?...
Ellipse is a part of BlockTableRecord and not part of BlockReference. You can have access to ellipse in BlockTableRecord and set it visible or invisible. But that setting will effect ALL BlockReference created from this BlockTableRecord (after regeneration of drawing).  If you create dynamic block you can manipulate property Visibility to hide/unhide ellipse and text individually in each BlockReference. Look at attached dwg-file.
Hallex
Message 2 of 19 (455 Views)
Re: How can I use a graphic ellipse with text together?
03-16-2013 07:49 AM in reply to: kevinsir
Hi Kevin,
Hallex
Message 3 of 19 (449 Views)
03-16-2013 08:39 AM in reply to: kevinsir
Though you could be read same code in Labs,
here is quick example
    [CommandMethod("OrderBlock", CommandFlags.Modal | CommandFlags.Redraw)]
        public static void CreateOrderLabel()
            // Get the current document and database
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                try
                    BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForWrite);
                    // get current text size for attribute or use hard coded one instead
                    double txtheight = db.Textsize;
                    // block name
                    string blkName = "ORDER";
                    // check if exists
                    if (bt.Has(blkName))
                        ed.WriteMessage("\nBlock \"ORDER\" already exist.");
                        return;// if exists then exit
                    BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                    Point3d inspt = new Point3d(0, 0, 0);
                    BlockTableRecord newBtr = new BlockTableRecord();
                    bt.Add(newBtr);
                    // change settings for you block to your suit:
                    newBtr.Name = blkName;
                    newBtr.Origin = inspt;
                    newBtr.BlockScaling = BlockScaling.Uniform;
                    newBtr.Units = UnitsValue.Inches;
                    newBtr.Explodable = false;
                    tr.AddNewlyCreatedDBObject(newBtr, true);
                    Vector3d normal = Vector3d.ZAxis;
                    Vector3d majorAxis = 6 * txtheight * Vector3d.XAxis;// change major axis to your suit
                    double radiusRatio = 0.4;// change ratio to your suit
                    double startAng = 0.0;
                    double endAng = Math.PI * 2;
                    Ellipse ellipse = new Ellipse(inspt, normal, majorAxis, radiusRatio, startAng, endAng);
                    ellipse.Layer = "0";
                    ellipse.LinetypeId = db.ContinuousLinetype;
                    ellipse.Color = Autodesk.AutoCAD.Colors.Color.FromColorIndex(ColorMethod.ByAci, 0);// color by block
                    ellipse.LineWeight = LineWeight.LineWeight040;// wide lineweight 0.40, change on LineWeight.ByLineWeightDefault to discard it
                    newBtr.AppendEntity(ellipse);
                    tr.AddNewlyCreatedDBObject(ellipse, true);
                    AttributeDefinition attr = new AttributeDefinition();
                    attr.Layer = "0";
                    attr.LinetypeId = db.ContinuousLinetype;
                    attr.Color = Autodesk.AutoCAD.Colors.Color.FromColorIndex(ColorMethod.ByAci, 0);// color by block
                    attr.LineWeight = LineWeight.ByLineWeightDefault;
                    attr.Tag = "DESCRIPTION";
                    attr.Prompt = "Order description:";
                    attr.TextString = "blah";
                    attr.Preset = true;
                    //attr.TextStyle = db.Textstyle;//<--   A2009
                    attr.TextStyleId = db.Textstyle;//<--   A2010
                    attr.Height = txtheight;
                    attr.Position = inspt;
                    attr.Justify = AttachmentPoint.MiddleCenter;
                    attr.AlignmentPoint = inspt;
                    attr.LockPositionInBlock = true;
                    attr.AdjustAlignment(db);
                    newBtr.AppendEntity(attr);
                    tr.AddNewlyCreatedDBObject(attr, true);
                    tr.Commit();
                    ed.Regen();
                catch (Autodesk.AutoCAD.Runtime.Exception ex)
                    ed.WriteMessage(ex.Message + "\n" + ex.StackTrace);
Valued Contributor
kevinsir
Message 4 of 19 (445 Views)
03-16-2013 08:57 AM in reply to: kevinsir
Thanks for your repy.If the attribute can show  and edit on the paper , It is maybe perfect.
I will try your code.
Hallex
Message 5 of 19 (439 Views)
03-16-2013 09:54 AM in reply to: kevinsir
Here is VB.NET code,see my poor comments inline
        <CommandMethod("OrderBlock", CommandFlags.Modal Or CommandFlags.Redraw)> _
        Public Shared Sub CreateOrderLabel()
            ' Get the current document and database
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Using tr As Transaction = db.TransactionManager.StartTransaction()
                Try
                    Dim bt As BlockTable = DirectCast(tr.GetObject(db.BlockTableId, OpenMode.ForWrite), BlockTable)
                    ' get current text size for attribute or use hard coded one instead
                    Dim txtheight As Double = db.Textsize
                    ' block name
                    Dim blkName As String = "ORDER"
                    ' check if exists
                    If bt.Has(blkName) Then
                        ed.WriteMessage(vbLf & "Block ""ORDER"" already exist.")
                        ' if exists then exit
                        Return
                    End If
                    Dim btr As BlockTableRecord = DirectCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
                    Dim inspt As New Point3d(0, 0, 0)
                    Dim newBtr As New BlockTableRecord()
                    bt.Add(newBtr)
                    ' change settings for you block to your suit:
                    newBtr.Explodable = False
                    tr.AddNewlyCreatedDBObject(newBtr, True)
                    Dim normal As Vector3d = Vector3d.ZAxis
                    Dim majorAxis As Vector3d = 6 * txtheight * Vector3d.XAxis
                    ' change major axis to your suit
                    Dim radiusRatio As Double = 0.4
                    ' change ratio to your suit
                    Dim startAng As Double = 0.0
                    Dim endAng As Double = Math.PI * 2
                    Dim ellipse As New Ellipse(inspt, normal, majorAxis, radiusRatio, startAng, endAng)
                    ellipse.Layer = "0"
                    ' color by block
                    ' wide lineweight 0.40, change on LineWeight.ByLineWeightDefault to discard it
                    tr.AddNewlyCreatedDBObject(ellipse, True)
                    Dim attr As New AttributeDefinition()
                    attr.Layer = "0"
                    ' color by block
                    attr.Preset = True
                    ' using current textstyle
                    'attr.TextStyle = db.Textstyle ''<--   A2009
                    attr.TextStyleId = db.Textstyle ''<--   A2010
                    attr.LockPositionInBlock = True
                    tr.AddNewlyCreatedDBObject(attr, True)
                    tr.Commit()
                    ed.Regen()
                Catch ex As Autodesk.AutoCAD.Runtime.Exception
                    ed.WriteMessage(ex.Message + vbLf + ex.StackTrace)
                End Try
            End Using
        End Sub
Valued Contributor
kevinsir
Message 6 of 19 (427 Views)
03-16-2013 08:48 PM in reply to: Hallex
Thanks a lot ! It is a nice solution. However, is there any better idea that if i want to edit description on the screen directly,never show a description dialogue.Because my customers use CAD on the pad ,maybe they want a big input UI.
Hallex
Message 7 of 19 (420 Views)
03-16-2013 11:25 PM in reply to: kevinsir
In this case discard show dialog using ATTDIA variable, see Help file
Cheers :smileyhappy:
Valued Contributor
kevinsir
Message 8 of 19 (418 Views)
03-17-2013 12:19 AM in reply to: Hallex
Can you tell me a more detailed method? Do  you mean that  when editing the attribute,  the dialogue also does not  appear ?
Valued Contributor
kevinsir
Message 9 of 19 (410 Views)
03-17-2013 04:25 AM in reply to: kevinsir
I mean can I  use this attribute like dbtext,
and another question is that is therer any setting i can set the attibute or the ellipse to be  visible or invisible!
Hallex
Message 10 of 19 (403 Views)
03-17-2013 06:03 AM in reply to: kevinsir
I have not have a time for testing and could not reach at AutoCAD now,
but you can play with attribite mode,
say specify your settings instead, e.g. in this line of code:
attr.Preset = True
You may want to play with something like
attr.Verify=true, same for Visible etc
