Why are you starting AutoCAD via Shell, rather than
using ActiveX ?
AutoCAD is an ActiveX server that can be started from
any ActiveX client.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
wrote in message news:5554559@discussion.autodesk.com...
Thanks to reply.
I am calling Autocad exe from vb form by using Shell command.
And my requirement is that when ever autocad is calling from this form having some parameters, Autocad new instance will open, do some work, and automatically close. Now it means that When ever any autocad instance will open, it check weather particular parameter comes or not, if not, then it is its normal running, otherwise the autoclosing scenario will works.......
Got my point??
I can do this by using alternate way that save valuesin text file and read when autocad opens. if values found........., , but it is not good approach.
Is there any proper one??
thanks again to reply.
