.NET
how can I make multi pallete with vb.net ?
2 REPLIES 2
h.sezenn
461 Views, 2 Replies
I have code like this:
'ensure single instance of this app...
Friend Shared m_ps As Autodesk.AutoCAD.Windows.PaletteSet = Nothing
' Define command
<CommandMethod("TestPalette")> _
Public Sub DoIt()
'check to see if paletteset is already created
If m_ps Is Nothing Then
'no so create it
m_ps = New Autodesk.AutoCAD.Windows.PaletteSet("My First Palette")
'create new instance of user control
Dim myPalette As Container1 = New Container1()
'add it to the paletteset
m_ps.Add("My First Palette", myPalette)
'turn it on
m_ps.Visible = True
End Sub
 in this code has a only one pallete ( tab ) but , ı want to make 4 or 5 pallete . how can I do thiswith vb.net ?
_____________________________________________________________________________________
Everything For Duct
2 REPLIES 2
_gile
in reply to: h.sezenn
The palette set tabs are the controls added to the palette set.
' Define command
Public Sub DoIt()
'no so create it
Dim myPalette1 As Container1 = New Container1()
m_ps.Add("My First Palette", myPalette1)
Dim myPalette2 As Container2 = New Container2()
m_ps.Add("My Second Palette", myPalette2)
Dim myPalette3 As Container3 = New Container3()
m_ps.Add("My Third Palette", myPalette3)
'and so on...
'turn it on
m_ps.Visible = True
End Sub
Gilles Chanteau
GileCAD
GitHub
h.sezenn
in reply to: _gile
Thank you so much. its works  🙂
Everything For Duct
”Boost
