.NET
How can I know user click discard or save when close the document?
3 REPLIES 3
443 Views, 3 Replies
I have a problem. I use AutoCAD 2010. I want  to know the use click save or discard button when close the document. I know the "Saved" Property of  AcadDocument can tell me the result. However, I could not use the AcadDocument Class. Because there is another plug-in, when i use the com class just like AcadDocument , it will tell some error.so i only can use .net Class just like Document. Is there any Proprty to get it ?
3 REPLIES 3
hgasty1001
Use some document and/or database event to do that. see the docs on events both database and document .
Gaston Nunez
in reply to: hgasty1001
Thanks for your reply!Can you give me some more information?
I think i have get the answer.
I use Application.GetSystemVariable("DBMOD"). when it is return 0  it is saved and when return 5 is discard
Thanks!
”Boost
