.NET
How can I insert rasterImage but not depend on the ori file outside?
6 REPLIES 6
kevinsir
799 Views, 6 Replies
How can I  bind the rasterImage as part of dwg file not depend on the ori file outside?
I use the imageattach order, However  when i delete the ori image or send the dwg file to others
the image is wrong.  How can i solve it ? Thanks.
6 REPLIES 6
Alfred.NESWADBA
in reply to: kevinsir
>> However  when i delete the ori image or send the dwg file to othersthe image is wrong.  How can i solve it ?
Use command _ETRANSMIT (>>>details<<<) to transfer your project data, so refrences will not be missed then.
You might insert it as OLE-object, but there are then some issues like file-size, some problems when printing (might be) and some more (read here in the forum about problems with OLE objects, for me: enough to avoid it)
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
kevinsir
in reply to: Alfred.NESWADBA
Thanks for your reply! If you can give me some code for example ,that will be perfect!
Alfred.NESWADBA
>> If you can give me some code [...]
Code to do what? Running the command _ETRANSMIT or embedding an ole-object into the drawing?
The command _ETRANSMIT is ready to use, there has nothing to be added, it exists 😉
OLE-embedding (which I would avoid as long as possible) ... have you searched here? There are already some threads: >>>click<<<
- alfred -
Alfred NESWADBA
kevinsir
Thanks,I will try it ,Then give  you a feedback
kevinsir
I read this code
[CommandMethod("InsertOle")]
public static void InsertOle()
Document doc = Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
Database refDb = new Database();
refDb.ReadDwgFile("c:\\Temp\\MyOleTemplate.dwg", System.IO.FileShare.Read, true, "");
using (Transaction Tx = db.TransactionManager.StartTransaction())
BlockTable bT = Tx.GetObject(db.BlockTableId, OpenMode.ForWrite) as BlockTable;
BlockTableRecord bTR = Tx.GetObject(bT[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
ObjectId btrId = db.Insert("MyOleTemplate", refDb, true);
BlockReference blockRef = new BlockReference(new Point3d(), btrId);
DBObjectCollection entitySet = new DBObjectCollection();
blockRef.Explode(entitySet);
foreach (object obj in entitySet)
if (obj is Ole2Frame)
Ole2Frame ole = obj as Ole2Frame;
bTR.AppendEntity(ole);
Tx.AddNewlyCreatedDBObject(ole, true);
Tx.Commit();
However I have two question about it.
1、Should MyOleTemplate.dwg be a special file that with the image I want to insert?
2、
can i use this code set   'ole ' to another image file  and  then the image file it will independ outside?
Balaji_Ram
How about using "WblockCloneObjects" to get the Ole2Frame from the other drawing ?
Here is a sample code that you can try :
Database destDb = doc.Database;
PromptResult prTableStyleName = ed.GetString("\nEnter drawing file path : ");
if (prTableStyleName.Status != PromptStatus.OK)
    return;
string dwgFilePath = prTableStyleName.StringResult;
if (!System.IO.File.Exists(dwgFilePath))
    return;
using (Database srcDb = new Database(false, true))
    srcDb.ReadDwgFile(dwgFilePath, System.IO.FileShare.Read, true, "");
    ObjectIdCollection oleObjectIds = new ObjectIdCollection();
    using (Transaction Tx = srcDb.TransactionManager.StartTransaction())
        BlockTable bT = Tx.GetObject(srcDb.BlockTableId, OpenMode.ForWrite) as BlockTable;
        BlockTableRecord btr = Tx.GetObject(bT[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
        foreach (ObjectId id in btr)
            if (id.ObjectClass.Name != "AcDbOle2Frame")
                continue;
            oleObjectIds.Add(id);
            break;
        Tx.Commit();
    if (oleObjectIds.Count > 0)
        ObjectId destBTRId = destDb.CurrentSpaceId;
        IdMapping iMap = new IdMapping();
        destDb.WblockCloneObjects(oleObjectIds, destBTRId, iMap, DuplicateRecordCloning.Replace, false);
        IdPair idPair = iMap.Lookup(oleObjectIds[0]);
        ObjectId newId = idPair.Value;
        if (newId.IsValid)
            PromptPointResult pr = ed.GetPoint("\nSelect insertion point: ");
            if (pr.Status == PromptStatus.OK)
                Point3d pt = pr.Value;
                using (Transaction Tx = destDb.TransactionManager.StartTransaction())
                    Ole2Frame ole2Frame = Tx.GetObject(newId, OpenMode.ForWrite) as Ole2Frame;
                    dynamic acadOle = ole2Frame.AcadObject;
                    double[] insertionPoint = new double[3];
                    insertionPoint[0] = pt.X;
                    insertionPoint[1] = pt.Y;
                    insertionPoint[2] = pt.Z;
                    acadOle.InsertionPoint = insertionPoint;
                    Tx.Commit();
Balaji
Developer Technical Services
Autodesk Developer Network
”Boost
