.NET
How Can I Get All Block Attributes and change it
9 REPLIES 9
Message 1 of 10
Amremad
988 Views, 9 Replies
hi every one
9 REPLIES 9
Message 2 of 10
HJohn1
in reply to: Amremad
Your request is open to many possibilities. You could ask the users to select a particular BlockReference or perhaps you already know which one you need to change and so on.  Here I am attaching a sample to change the AttributeReference TextString of all the BlockReferences on the drawing which have attributes.  Hope it helps or gives you some ideas.
Public Sub GetAllAttributes()
            Dim Ed As Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
            Dim Doc As Autodesk.AutoCAD.ApplicationServices.Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim DocLock As Autodesk.AutoCAD.ApplicationServices.DocumentLock
            Dim Db As Database = HostApplicationServices.WorkingDatabase
            Dim Ids As New ObjectIdCollection
            Dim BlkTblRec As BlockTableRecord
            Dim AttRef As AttributeReference
            Dim BlkRef As BlockReference
            Dim BlkTbl As BlockTable
            Dim AttRefId As ObjectId
            Dim RefId As ObjectId
            Dim Id As ObjectId
            Dim Mtxt As MText
            DocLock = Doc.LockDocument
            Try
                Using Trans As Transaction = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction
                    BlkTbl = CType(Trans.GetObject(Db.BlockTableId, OpenMode.ForRead), BlockTable)
                    For Each Id In BlkTbl
                        BlkTblRec = CType(Trans.GetObject(Id, OpenMode.ForRead), BlockTableRecord)
                        If BlkTblRec.HasAttributeDefinitions = True Then
                            Ids = BlkTblRec.GetBlockReferenceIds(False, False)
                            If Ids.Count > 0 Then
                                For Each RefId In Ids
                                    BlkRef = CType(Trans.GetObject(RefId, OpenMode.ForWrite), BlockReference)
                                    For Each AttRefId In BlkRef.AttributeCollection
                                        AttRef = CType(Trans.GetObject(AttRefId, OpenMode.ForWrite), AttributeReference)
                                        If AttRef.IsMTextAttribute Then
                                            Mtxt = AttRef.MTextAttribute
                                            Mtxt.Contents = "New TextString"
                                            AttRef.MTextAttribute = Mtxt
                                            AttRef.UpdateMTextAttribute()
                                        Else
                                            AttRef.TextString = "New TextString"
                                        End If
                                    Next
                                Next
                            End If
                        End If
                    Next
                    Trans.Commit()
                End Using
            Catch ex As Exception
                MessageBox.Show(ex.Message, "Changing Attributes", MessageBoxButtons.OK, MessageBoxIcon.Error)
            Finally
                DocLock.Dispose()
            End Try
        End Sub
Message 3 of 10
DiningPhilosopher
in reply to: HJohn1
You should probably take some time to read the docs for the APIs you're attempting to use in that code, to understand them better.
GetBlockReferenceIds( false, false ) will return the ids of any block that is directly or indirectly inserted into the block whose BlockTableRecord you invoke the method on.
Since your code is iterating over the entire contents of the BlockTable, the 'false' argument to GetBlockReferenceIds() is redundant.
Message 4 of 10
HJohn1
in reply to: DiningPhilosopher
DP you advice has been well taken, thank you for pointing it out and sharing your knowledge.  I really wish I could be able to understand everything I read on the docs.  I guess that perhaps the documentation has been wrintten by people who know for people who know, not for the layperson like me.
Message 5 of 10
Amremad
in reply to: HJohn1
sorry for late
i was very sick , but now iam good , thanks god
thank you very much MR. HJohn1 for helping me
Message 6 of 10
Amremad
thanks MR. DiningPhilosopher for you advice
i promise you i will do than
Message 7 of 10
jaboone
I need this type of thing too.  Thanks for posting.  I am getting some errors when I just plugged it into my code.  Is there an Autodesk dll I forgot to include causing the error past Autodesk.AutoCAD.ApplicationServices.?
Thanks.
Learning as I go
Message 8 of 10
Amremad
in reply to: jaboone
Mr.  Jaboone
can you send me your source code to see what's a problem !!!
and tell me what's the version of cad  and framework ?
Message 9 of 10
It seems that when I put the code in a tutorial there were no errors, but then putting it in another, it had fewer errors.  Let me investigate why and I will get back.
Message 10 of 10
Amremad
 i think you , you must choose the correct framework version
”Boost
