.NET
Amremad
Message 1 of 10 (531 Views)
How Can I Get All Block Attributes and change it
531 Views, 9 Replies
05-22-2013 03:46 AM
hi every one
Your request is open to many possibilities. You could ask the users to select a particular BlockReference or perhaps you already know which one you need to change and so on.  Here I am attaching a sample to change the AttributeReference TextString of all the BlockReferences on the drawing which have attributes.  Hope it helps or gives you some ideas.
Public Sub GetAllAttributes()
Dim Ed As Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
Dim Doc As Autodesk.AutoCAD.ApplicationServices.Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim DocLock As Autodesk.AutoCAD.ApplicationServices.DocumentLock
Dim Db As Database = HostApplicationServices.WorkingDatabase
Dim Ids As New ObjectIdCollection
Dim BlkTblRec As BlockTableRecord
Dim AttRef As AttributeReference
Dim BlkRef As BlockReference
Dim BlkTbl As BlockTable
Dim AttRefId As ObjectId
Dim RefId As ObjectId
Dim Id As ObjectId
Dim Mtxt As MText
DocLock = Doc.LockDocument
Try
Using Trans As Transaction = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction
BlkTbl = CType(Trans.GetObject(Db.BlockTableId, OpenMode.ForRead), BlockTable)
For Each Id In BlkTbl
BlkTblRec = CType(Trans.GetObject(Id, OpenMode.ForRead), BlockTableRecord)
If BlkTblRec.HasAttributeDefinitions = True Then
Ids = BlkTblRec.GetBlockReferenceIds(False, False)
If Ids.Count > 0 Then
For Each RefId In Ids
BlkRef = CType(Trans.GetObject(RefId, OpenMode.ForWrite), BlockReference)
For Each AttRefId In BlkRef.AttributeCollection
AttRef = CType(Trans.GetObject(AttRefId, OpenMode.ForWrite), AttributeReference)
If AttRef.IsMTextAttribute Then
Mtxt = AttRef.MTextAttribute
Mtxt.Contents = "New TextString"
AttRef.MTextAttribute = Mtxt
AttRef.UpdateMTextAttribute()
Else
AttRef.TextString = "New TextString"
End If
Next
Next
End If
End If
Next
Trans.Commit()
End Using
Catch ex As Exception
MessageBox.Show(ex.Message, "Changing Attributes", MessageBoxButtons.OK, MessageBoxIcon.Error)
Finally
DocLock.Dispose()
End Try
End Sub
Distinguished Contributor
HJohn1
Message 2 of 10 (516 Views)
Re: How Can I Get All Block Attributes and change it
05-22-2013 05:46 AM in reply to: Amremad
            Dim Id As ObjectId
            Dim Mtxt As MText
            Try
                                        Else
                                        End If
                                    Next
                                Next
                            End If
                        End If
                    Next
                    Trans.Commit()
                End Using
            Finally
                DocLock.Dispose()
            End Try
        End Sub
Valued Mentor
DiningPhilosopher
Message 3 of 10 (491 Views)
05-22-2013 04:20 PM in reply to: HJohn1
You should probably take some time to read the docs for the APIs you're attempting to use in that code, to understand them better.
GetBlockReferenceIds( false, false ) will return the ids of any block that is directly or indirectly inserted into the block whose BlockTableRecord you invoke the method on.
Since your code is iterating over the entire contents of the BlockTable, the 'false' argument to GetBlockReferenceIds() is redundant.
HJohn1
Message 4 of 10 (467 Views)
05-23-2013 07:02 AM in reply to: DiningPhilosopher
DP you advice has been well taken, thank you for pointing it out and sharing your knowledge.  I really wish I could be able to understand everything I read on the docs.  I guess that perhaps the documentation has been wrintten by people who know for people who know, not for the layperson like me.
Amremad
Message 5 of 10 (409 Views)
06-02-2013 02:13 AM in reply to: HJohn1
sorry for late
i was very sick , but now iam good , thanks god
thank you very much MR. HJohn1 for helping me
Amremad
Message 6 of 10 (407 Views)
06-02-2013 02:14 AM in reply to: DiningPhilosopher
thanks MR. DiningPhilosopher for you advice
i promise you i will do than
Valued Contributor
jaboone
Message 7 of 10 (369 Views)
06-04-2013 05:51 AM in reply to: Amremad
I need this type of thing too.  Thanks for posting.  I am getting some errors when I just plugged it into my code.  Is there an Autodesk dll I forgot to include causing the error past Autodesk.AutoCAD.ApplicationServices.?
Thanks.
Learning as I go
Amremad
Message 8 of 10 (346 Views)
06-05-2013 01:39 AM in reply to: jaboone
Mr.  Jaboone
can you send me your source code to see what's a problem !!!
and tell me what's the version of cad  and framework ?
jboone
Message 9 of 10 (333 Views)
06-05-2013 07:00 AM in reply to: Amremad
It seems that when I put the code in a tutorial there were no errors, but then putting it in another, it had fewer errors.  Let me investigate why and I will get back.
Amremad
Message 10 of 10 (327 Views)
06-05-2013 07:13 AM in reply to: jboone
 i think you , you must choose the correct framework version
