.NET
How can I display the object data of a layer in table format, with VB.net.
2 REPLIES 2
newautocad123
363 Views, 2 Replies
How can I display the object data of a layer in table format, with VB.net. or How can I display the attributes of a .SHP file, edit it and also add new point to it.
Please suggest examples url to follow.
2 REPLIES 2
FeatIdFeatId1OBJECTIDcitycodeCitynamecountrymintempmaxTempPopulationlatlong
24313567735677101DelhiIndia24810000077.1128.4
24353567835678102BangaloreIndia63228900078.113.2
24393567935679103LondonUK101647800079.09-2
24433568035680104newYorkUS14066700080.08-17.2
24473568135681105AustinUS18-1685600081.07-32.4
24513568235682106BerlinGermany22-32104500082.06-47.6
Balaji_Ram
in reply to: newautocad123
Sorry, I dont have a ready code snippet to do that.
If you are new to AutoCAD API, then I suggest going through the introductory topics available for download here :
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=16459234
Displaying the values after they are retrieved is a general .Net programming topic on which you can find help elsewhere.
If you have a specific question related to the AutoCAD API, please post a sample code that you are having problem with.
Balaji
Developer Technical Services
Autodesk Developer Network
”Boost
