.NET
.NET
Valued Mentor
23 Kudos
Post 1 of 7
How can I count the number of deactivated documents ?
229 Views, 6 Replies
03-12-2013 04:01 PM
Hi.
I´m using the events "DocumentActivated" and  the event "DocumentDestroyed" .
With the "DocumentDestroyed" method I can know how many documents are closed and when is the last..
But, I want to know, how many documents are minimized (deactivated).
It´s to say, there aren´t any active (current) document.
Trank you.
Autocad Civil 3D 2014 +SP1+SP2 // Civil 3D 2015 +SP1
Quad Core Intel i7 3770-cpu 3.40Ghz.
ssd samsung 840 pro 512gb+ssd samsung 840 pro 256 gb+1tb hdd
32gb RAM 1600 Mhz.
nVidia Quadro 2000.
Win 7 Pro 64bit
Valued Mentor
175 Kudos
Post 2 of 7
Re: How can I count the number of deactivated documents ?
03-12-2013 09:12 PM in reply to: joantopo
The DocumentCollection's Count property tells you how many documents exist.
There can be only one active document so the number of 'deactivated' documents is the value of the Count property minus 1.
When the DocumentToBeDestroyed event fires, if the document that's about to be destroyed is the only open document, then at that point, the DocumentCollection's Count property will be 1, and it means that AutoCAD is entering 'zero document state' (where there are no open documents).
Valued Mentor
23 Kudos
Post 3 of 7
03-13-2013 02:17 AM in reply to: DiningPhilosopher
ok, but if I have all my documents as a(deactivated) documents. Which is the active document?  What´s the name or Id of this?
Because I can have all my documents as a deactivated document.
Thank you for reply.
32gb RAM 1600 Mhz.
nVidia Quadro 2000.
Win 7 Pro 64bit
Valued Mentor
53 Kudos
Post 4 of 7
03-13-2013 04:29 AM in reply to: joantopo
 How do you do that?
If you have them all "deactivated" then how could one active?
I just noticed you mention minimized so when you say "deactivated" you mean minimized?
You can still enter commands and interact with active document when all them all minimized, but I think your looking for
Application.DocumentManager.MdiActiveDocument.Window.WindowState
You can also find your answers @ TheSwamp
Valued Mentor
23 Kudos
Post 5 of 7
03-13-2013 04:56 AM in reply to: jeff
Yes, all right.
I was confusing deactivated with minimized.  I wanted to say "minimized".
I´m going to try this line code.
Thank you.
32gb RAM 1600 Mhz.
nVidia Quadro 2000.
Win 7 Pro 64bit
Valued Mentor
23 Kudos
Post 6 of 7
03-13-2013 05:42 AM in reply to: joantopo
I don´t understand because Autodesk interpret that the window state = normal is the same that state=minimized..:smileyfrustrated:
                 private void callback_documentActivated(object sender, DocumentCollectionEventArgs e)
                  if (ComprobarTodosMinimizados()==false)
                     System.Windows.Forms.MessageBox.Show("abiertoooooooo");
                  else
                      System.Windows.Forms.MessageBox.Show("todos minimizados");
                 public bool ComprobarTodosMinimizados()
                     bool TodosMinimizados = false;
                     int contador = 0;
                     DocumentCollection docs = Application.DocumentManager;
                     foreach (Document doc in docs)
                        if (doc.Window.WindowState == Autodesk.AutoCAD.Windows.Window.State.Minimized);  // si se minimiza la ventana
                            contador++;
                     if (contador == Application.DocumentManager.Count)
                         TodosMinimizados = true;
                 return TodosMinimizados;
32gb RAM 1600 Mhz.
nVidia Quadro 2000.
Win 7 Pro 64bit
Valued Mentor
23 Kudos
Post 7 of 7
03-13-2013 05:52 AM in reply to: joantopo
is this right?
32gb RAM 1600 Mhz.
nVidia Quadro 2000.
Win 7 Pro 64bit
