.NET
.NET
Valued Contributor
kevinsir
Message 1 of 8 (361 Views)
How can I catch the message or event when I begin to edit Mtext entity?
361 Views, 7 Replies
09-12-2012 09:00 PM
Hello!Is there anyway I can catch the message or event when I begin to edit Mtext entity?
Because I want to do something when the mtext   began to input
Anyone can help me? Thanks
khoa.ho
Message 2 of 8 (353 Views)
Re: How can I catch the message or event when I begin to edit Mtext entity?
09-12-2012 11:03 PM in reply to: kevinsir
You can add an event to the editor for mouse dragging before defining an MText box:
[CommandMethod("CatchAddedMText")]
public static void CatchAddedMText()
	Document doc = Application.DocumentManager.MdiActiveDocument;
	Editor ed = doc.Editor;
	ed.Dragging += EdOnDragging;
private static void EdOnDragging(object sender, DraggingEventArgs draggingEventArgs)
	var ed = (Autodesk.AutoCAD.EditorInput.Editor)sender;
	if (ed.Document.CommandInProgress == "MTEXT")
		// Do something here before the MText begin to input
The event LeavingQuiescentState catches the editor entering busy mode, it will not know the ongoing command.
The event PointMonitor gets called every time when moving the mouse so it will not use as it consumes the CPU resource.
We try to use an event that is typical to draw MText and less called from the editor event handler. I think the event Dragging is a good choice to capture MText creation, and allow to do something before typing the MText.
-Khoa
khoa.ho
Message 3 of 8 (347 Views)
09-12-2012 11:26 PM in reply to: kevinsir
I revise the code for modifying an existing MText, the previous code is just for creating a new MText:
[CommandMethod("CatchMTextEvents")]
public static void CatchMTextEvents()
	// Event for MText creation
	// Event for MText modifying
	ed.PromptForEntityEnding += EdOnPromptForEntityEnding;
private static void EdOnPromptForEntityEnding(object sender, PromptForEntityEndingEventArgs promptForEntityEndingEventArgs)
	var ed = (Autodesk.AutoCAD.EditorInput.Editor) sender;
	if (ed.Document.CommandInProgress == "DDEDIT")
		// Do something here before the MText begin to modify
-Khoa
Valued Contributor
kevinsir
Message 4 of 8 (322 Views)
09-13-2012 09:59 PM in reply to: kevinsir
Thanks for your rely ! I will try !
Valued Contributor
kevinsir
Message 5 of 8 (315 Views)
09-14-2012 01:47 AM in reply to: kevinsir
I'm sorry that "EdOnPromptForEntityEnding" is not work in CAD2008! e...Do you know other event about that? Because I want the event when the curor is appearing and word  can be input !
khoa.ho
Message 6 of 8 (298 Views)
09-14-2012 08:09 AM in reply to: kevinsir
I tested this code works on AutoCAD 2009, and the latest 2013. I don't use AutoCAD 2008 now so I don't know which event methods are available on 2008 but missing from 2009 and above.
This solution is not really perfect. The idea is to catch the current command in progress on the editor event handler. If the current command is DDEDIT (type ED in AutoCAD), it will catch the MText on beginning to modify. It will not work if you double-click to edit the selected MText. You can play around with other event methods in AutoCAD 2008 to find out which one is most closed to the PromptForEntityEnding event.
Another solution is to search for all MTexts of the current drawing database, then bind them with the event Modified. And for each MText creation, you have to bind this event method to it.
I think might someone have another idea with MText overrule, or something else. This topic is open for everyone who has the good solutions.
-Khoa
Valued Contributor
kevinsir
Message 7 of 8 (282 Views)
09-14-2012 04:32 PM in reply to: kevinsir
Thank you very much to give me so much help!I will try your suggestion again!
Valued Contributor
kevinsir
Message 8 of 8 (233 Views)
09-17-2012 11:27 PM in reply to: khoa.ho
Hi! EveryOne ,Mybe I have solved it
For add Mtext I use three event
private bool startcontrol=false;
private  void ed_DraggingEnded(object sender, DraggingEndedEventArgs e)
if (startcontrol)
OpenForm(false);
startcontrol = false;
private void ed_PromptingForPoint(object sender, PromptPointOptionsEventArgs e)
if (e.Options.Keywords.Count == 7)
startcontrol = true;
return;
private  void ed_PromptedForPoint(object sender, PromptPointResultEventArgs e)
if (e.Result.Status == PromptStatus.OK)
if (startcontrol)
return;
private void OpenForm(bool b)
///Then for edit the mtext I use another three events which could cover double-click mtext and input Mtedit command
private void EdOnPromptForEntityEnding(object sender, PromptForEntityEndingEventArgs promptForEntityEndingEventArgs)
if (ed.Document.CommandInProgress =="MtEdit")
private  void Database_ObjectOpenedForModify(object sender, ObjectEventArgs e)
if (e.DBObject.ClassID.ToString() == MtextguidClass)
if (startcontrol)
OpenForm(true);
private void ed_PromptForSelectionEnding(object sender, PromptForSelectionEndingEventArgs e)
Database database = ((Autodesk.AutoCAD.EditorInput.Editor)sender).Document.Database;
if (e.Selection.Count == 1)
using (Transaction tr = database.TransactionManager.StartTransaction())
                    ObjectId[] objectids = e.Selection.GetObjectIds();
                    DBObject dbobject = objectids[0].GetObject(OpenMode.ForRead);
if (dbobject.ClassID.ToString() == MtextguidClass)
{                         startcontrol = true;
return;
Maybe it is not perfect ,But has reached my request!
