.NET
.NET
0 Kudos
Post 1 of 3
how can I cancel my sub when I press right click or escape?
326 Views, 2 Replies
11-04-2013 09:58 AM
Hello friends;
I have 4 question actually.
1 quesiton:
I have program with do...loop while
I draw line(they are also block) but, when I press right click it doesnt exit sub?
how can I exit sub when I press escape or right click?
2 question:
When I press escape my programme add a new line. but I dont want it to add my draw. how Can I solved this issue?
3. question
I want to draw a line with temporary dimention( as you see picture) is it possible?
4 question
is appear any icon when I get on my line block ?( **** yo see on picture )( green plus)
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
Imports System.Windows.Input
Imports System.Windows.Forms
Public Class Class4
    <CommandMethod("deneme")> _
    Public Sub cizgiciz()
        Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Dim ed As Editor = doc.Editor
        Dim x As Integer
        x = 0
        Dim pPtRes As PromptPointResult
        Dim pPtOpts As PromptPointOptions = New PromptPointOptions("")
        pPtOpts.Message = vbLf & "NOKTA SEÇ:  "
        pPtRes = doc.Editor.GetPoint(pPtOpts)
        Dim ptStart As Point3d = pPtRes.Value
        Do
            x = x + 1
            Dim blockName As String = "CİZGİ" & x
            pPtOpts.Message = vbLf & "2.NOKTAYI SEÇ : "
            pPtOpts.UseBasePoint = True
            pPtOpts.BasePoint = ptStart
            Dim ptEnd As Point3d = pPtRes.Value
            Using tr As Transaction = db.TransactionManager.StartTransaction()
                Dim bt As BlockTable = DirectCast(tr.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
                If Not bt.Has(blockName) Then
                    Dim btr As New BlockTableRecord()
                    btr.Name = blockName
                    btr.Origin = ptStart
                    bt.UpgradeOpen()
                    Dim btrId As ObjectId = bt.Add(btr)
                    tr.AddNewlyCreatedDBObject(btr, True)
                    Dim line As New Line(ptStart, ptEnd)
                    line.ColorIndex = x
                    line.LineWeight = LineWeight.LineWeight050
                    btr.AppendEntity(line)
                    tr.AddNewlyCreatedDBObject(line, True)
                    If btrId <> ObjectId.Null Then
                        Using acBlkRef As New BlockReference(ptStart, btrId)
                            Dim acCurSpaceBlkTblRec As BlockTableRecord
                            acCurSpaceBlkTblRec = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite)
                            acCurSpaceBlkTblRec.AppendEntity(acBlkRef)
                            tr.AddNewlyCreatedDBObject(acBlkRef, True)
                        End Using
                    End If
                    tr.Commit()
                End If
            End Using
            ptStart = ptEnd
        Loop While pPtRes.Status = PromptStatus.OK
    End Sub
End Class
_____________________________________________________________________________________
Everything For Duct
There are reasons that all the Editor.GetXXX() method return an PromptXXXXResult object instead of directly returniong the value the GetXXXX(0 is supposed to get (Point, Entity, Integer, String....), because user can press Esc to cancel the method, or enter wrong type of data. You need ALWAYS to test the status of PromptXXXResult before reaching the value inside. So, after your this line of code:
You MUST do
If pPtRes.Status=PromptStatus.OK Then
   ''You only know at this moment that a point is picked
Else
   ''You quit the loop here
   Exit Do
End If
Once you understand you need to test PromptStatus of the returned PromptXXXXResult object, you probably be able to answer the questions you asked.
215 Kudos
Post 2 of 3
Re: how can I cancel my sub when I press right click or escape?
11-05-2013 08:18 AM in reply to: h.sezenn
You MUST do
Else
   Exit Do
End If
0 Kudos
Post 3 of 3
11-06-2013 11:48 AM in reply to: norman.yuan
Thank you your answer :smileyhappy:
İ did it. itworked. :smileyhappy:
when I press ESC programme stopped.
Everything For Duct
