Solved by Keith.Brown. Go to Solution.
Yes,
You should monitor the DocumentCreated event of the DocumentCollection. It should fire when a new drawing is either created or an existing drawing is opened. Once that happens you can write the Database.FileName to a file.
AutoCAD Help File: http://help.autodesk.com/view/ACD/2016/ENU/?guid=GUID-E619BB54-D531-4640-BB74-B61E6CA13238
Some extra information about Database.Filename: http://forums.autodesk.com/t5/net/database-filename-return-autosave-filename-sv/td-p/4401703
How to write to a file c#: https://msdn.microsoft.com/en-us/library/8bh11f1k.aspx
Check if a newly created drawing has been named: http://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/AutoCA...
